[GRASSLIST:3151] [New User Creating first Location]
Ooops, I sent this to grass@baylor.edu instead of grasslist@baylor.edu.
No wonder no one answered.
-----Forwarded Message-----
To: grass@baylor.edu
Subject: New User Creating first Location
Date: Mon, 12 Apr 2004 05:02:12 -0600
I'm working on getting a copy fo the Open Source GIS book.
In the meantime I'm trying to get by with the documentation
I can find online.
When creating a new location I am asked to
    Enter Zone:
This is not mentioned in any of the tutorial I have found so far.
If I control-c past this I'm asked to set up my default region,
but I'm not clear on the units to use when filling out this form.
The region resolution makes sense, but it seems that you only want
it to apply to the layers involved in a computational model.
For other layers: doq, drg, etc. I would want to keep the full
resolution of the source. Because I want use them to paint a
background image once the computation is done. When reviewing
the results I want to focus on particular subregions, between the
river and the highway, north of this and south of that. This
is easiest using a "full resolution" background image.
drew einhorn <drew@technteach.com>
Technology and Teaching
   Enter Zone:
Are you creating a UTM location? If so, that would be the UTM zone. If you are creating a State Plane location, enter 'list' and it will prompt you thru some options.
The units would be based on your projection. Meters for UTM, degrees for lat/lon, maybe feet for State Plane. Make a guess, but don't worry because it can be changed easily. In fact you will probably change it frequently during the course of your work.
Best way to import raster data is with r.in.gdal -oe ... The -oe Over-rides the resolution and Extends the extent of the region if necessary. So again, don't stress about your initial settings, they will not restrict you.
Richard Greenwood
www.greenwoodmap.com
Yes: what it prompts you for at the location set-up stage is the *default*
region & resolution, which is really fairly meaningless as almost all
modules use the *current* region & resolution to perform all their
options. So, while having a think about what it means is useful to help
understand your data and how GRASS works, it is not important now and you
can really just skip this stage and set the region after you import your
data.
necessary.
As I understand it the -o flag overrides the projection check (not the region):
this wouldn't be a good idea if the projection was not set up correctly to
start with. Better to use the location= parameter to generate a new
location with the correct projection.
And somebody correct me if I'm wrong about this but the -e flag extends
the default region, which IMHO there's not much point in doing because it
is fairly meaningless as I said above. But in my experience if the -e flag
is not used then r.in.gdal doesn't change the region at all (which is how
it should be because e.g. if you're doing a batch import of multiple files
and want to do some other processing while it's going on you don't want
the background process messing around with the region settings).
HOWEVER, looking at the source code of r.in.gdal it seems this behaviour
was not intended. We have:
/* Set up the window representing the data we have. */
    cellhd.rows = GDALGetRasterYSize(hDS);
    cellhd.cols = GDALGetRasterXSize(hDS);
... and other functions for getting resolution etc. from GDAL and storing
in the cellhd struct ...
and then later on:
/* Set the active window to match the available data. */
    if(G_set_window (&cellhd) < 0)
        exit(3);
i.e. r.in.gdal is attempting to change the current region to match the
resolution of the data (IMHO a bad idea as I said above). So this function
G_set_window() seems not to work and in my experience looking at v.in.ogr
for 5.7 it used some caching mechanism that made it think nothing had
changed and you had to use G__put_window() to force the change. My memory
is not perfect on this but it was something like that. The code is not in
the current v.in.ogr though.
So, summary of suggestion for improvement: The -e flag should be used to either
extend or (preferably) set the *current* region (i.e. the code for this should
first be fixed and then made conditional on the -e flag) and the bit about
extending the default region should be removed. Or has anybody ever found a
good use for extending the default region rather than the current region?
If you don't use the -e flag when running r.in.gdal then you must use
g.region rast=xxx to set the region to match your data (which is I think
how it works currently and how it should be but perhaps not how it was
intended to be).
not restrict you.
Exactly.
Paul.
