[GRASSLIST:3164] Proper input for r.sunmask (GRASS5.3)
Hi all!
I'm trying to use r.sunmask in order to calculate shadowed areas. My DEM's
resolution is 5x5 meters and it has an extension of 4x4 km.
r.sunmask appears to hang at 0% when calculating shadows for DEM(after
having succesfully calculated sun position). Should i be more patient? or is
it something wrong?
Thanks a lot
Javier Yebrin
On Wed, Apr 14, 2004 at 03:53:31PM +0200, Javier A. Yebrin wrote:
Hi all!
it something wrong?
r.sunmask is just extremely slow.
A trick: use r.sun instead:
http://grass.itc.it/gdp/html_grass5/html/r.sun.html
- use -s flag
- "A map of shadows can be extracted from the solar incidence
    angle map (incidout). Areas with zero values are shadowed."
Hope this helps,
> Hi all!
> areas.
Thanks, i'll try that later. I want to see first how does r.sunmask
performs. It's been running for 20 hours and its on 72%.
(Grass53 on AlphaStation 500 - 400Mhz -256 Mb RAM - 1 gb used swap)
Regards.
Javier
- use -s flag
Hope this helps,
