Hello, I have a problem compiling new commands.
When I try to run "gmake53 -i" i get the following error:
[root@maxi Interception]# /usr/local/bin/gmake53 -i
SRC = /home/mcannata/grass53_exp_2004_03_27/src
CMD = /home/mcannata/grass53_exp_2004_03_27/src/CMD
UNUSED = /home/mcannata/grass53_exp_2004_03_27/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE = /home/mcannata/grass53_exp_2004_03_27/dist.i686-pc-linux-gnu
VERSION = 5.3-cvs 2004
/home/mcannata/grass53_exp_2004_03_27/ModelloIST/Interception
make -f OBJ.i686-pc-linux-gnu/make.rules
make: `/home/mcannata/grass53_exp_2004_03_27/dist.i686-pc-linux-gnu/etc/bin/cmd/r.interception' is up to date. make -f OBJ.i686-pc-linux-gnu/make2.rules
gcc -L/home/mcannata/grass53_exp_2004_03_27/src/libes/LIB.i686-pc-linux-gnu -Wl,--export-dynamic -o /etc/bin/cmd/r.interception OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/functions.o -lgis -lm -lz
/usr/bin/ld: cannot open output file /etc/bin/cmd/r.interception: No such file or directory
collect2: ld returned 1 exit status
make: *** [/etc/bin/cmd/r.interception] Error 1
Why does it try to make it in /etc/bin/cmd/r.interception ? The new code are in the current directory:
I have installed grass53 with the options --prefix=/home/grass and --bindir=/home
Suggestions???
Thanks again.
note: change my e-mail reference to massimiliano.cannata@supsi.ch
because the old one will be deleted soon.
Ing. Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata@supsi.ch
Internet: http://www.ist.supsi.ch
