[GRASSLIST:3198] my first question
Can GRASS do topological operations, like intersection, union and buffering for polygon, line and point?
Thanks
Yes, but only in the new GRASS 5.7 version.
see:
http://mpa.itc.it/radim/g51/index.html
http://grass.ibiblio.org/grass51/tutorial/vectoroverlay.html
http://grass.ibiblio.org/grass51/tutorial/index.html
(GRASS 5.1 was renamed GRASS 5.7)
Hamish
On Sat, Apr 17, 2004 at 08:47:42AM -0700, Fei Li wrote:
Yes, have a look at GRASS 5.7:
http://grass.itc.it/grass51/manuals/html57_user/vector.html
v.buffer
v.overlay
Some screenshots are here:
(note: GRASS 5.1 = 5.7)
Thanks
----- Original Message -----
To: <GRASSLIST@baylor.edu>
Sent: Sunday, April 18, 2004 4:14 AM
Subject: [GRASSLIST:3202] Re: my first question
> Hi,
v.buffer
v.overlay
After I read the tutorial I know what function GRASS has but I have no idea
how to work on it. So the tutorial is a realy an overview.
I need a real tutorial it can teach me how to work on GRASS step by step
through an example data set. Who can introduce one to me?
Thanks
I want to make PC application and to take some function from GRASS. Which
libraries in GRASS are ANSI C or close to ANSI C. Is that hard to rewrite
GIS library and VECTOR library to ANSI C style? Is there any hidden dead
end?
Thanks
On Mon, 19 Apr 2004, Fei Li wrote:
This is what Thierry is doing; see http://www.kergis.org/
It also has a different licence from GRASS, so is potentially better for
including within other applications (that is the aim of it).
Paul
Is a cygwin expert here? I have problem with it?
I have downloaded and installed it yesterday. When I run some configure
files it can stop on the half way and if I run them again it can go through,
why is that?
Thanks
