Afraid I'm rather new to all this. Just trying to read in a shape file
as in the Tutorial. Below are the steps I have gone through.
I'm running Red Hat Enterprise 3 and using their Postgresql database.
Thanks!
Craig
GRASS 5.7.-cvs:~/grass57/netdown/Orig_L1/play > db.connect driver=pg
database="dbname=L1,user=caumann"
driver:pg
database:dbname=L1,user=caumann
GRASS 5.7.-cvs:~/grass57/netdown/Orig_L1/play > v.format
g.gisenv store=mapset set=GV_FORMAT=POSTGIS
g.gisenv store=mapset set=GV_PGIS_DATABASE=dbname=L1,user=caumann
GRASS 5.7.-cvs:~/grass57/netdown/Orig_L1/play > v.database driver=pg
GRASS 5.7.-cvs:~/grass57/netdown/Orig_L1/play > v.in.ogr
dsn=conl1a_fin.shp output=l1ashp A datum name nad27
(North_American_Datum_1927) was specified without transformation
parameters.
WARNING: Non-interactive mode: the GRASS default for nad27 is
towgs84=-22.000,157.000,176.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
D2/3: Vect_open_new(): name = l1ashp
D1/3: Vect_set_thresh(): thresh = 0.000000
D3/3: format = 2
D1/3: V1_open_new_post()
D3/3: set_frmt_post(): name = l1ashp
D3/3: parse_conn()
D3/3: parse_conn : dbname=L1,user=caumann
D3/3: token 0 : dbname=L1
D3/3: token 1 : user=caumann
D2/3: db = dbname=L1,user=caumann
D2/3: host = (null) port = (null) options = (null) tty = (null)
D2/3: database = L1 user = caumann password = (null)
D3/3: setup()
D1/3: SELECT COUNT (tablename) FROM pg_tables WHERE tablename =
'l1ashp_geom'
'l1ashp_cat'
D1/3: CREATE TABLE l1ashp_geom ( id int4 PRIMARY KEY, type int4 CHECK
((type > 0) AND (type < 5)), geom geometry);
WARNING: Cannot create geometry table
ERROR: Type "geometry" does not exist
ERROR: Cannot open new vector l1ashp@caumann
