[GRASSLIST:3264] Re: [GRASS5] Hugarian and other ISO8859-2 languages in GRASS
I'm not sure, but once I read, that someone wrote about
implementation hungarian (and other ISO8859-2) specific letters in
GRASS. The problem was resolved at about 2 years ago. It is possible
to use those letters in GRASS monitor and with printer commands. The
GRASS polish fonts are from 2 years available, and (after some
letters) now I've decided to create the GRASS fonts with all ISO8859-2
fonts and HOWTO. I suppose, they will be ready to use at the end of
may. I've created tools (http://wgug.meteo.uni.wroc.pl/ - link
"pliki" - take three last files and unpack - documentation is in
english & pilish language. With these tools you can very easy
create/modify GRASS fonts.
You can probably just use d.text.freetype to display most (but not yet all)
TrueType fonts on your system.
try:
d.text.freetype path=/path/to/font.ttf
see also:
d.text, d.font
regards,
Hamish
However, it has to have been built with iconv support in order to
display anything other than ISO-8859-1.
Also, that doesn't help for programs which use the GRASS stroke fonts
(e.g. d.legend).
