[GRASSLIST:3299] GRASS 5.7 libraries
I am new to all of this stuff so forgive me if this question is dumb. I have loaded GRASS 5.7 on my computer running Fedora Core 1. It won’t open and I assume it has to do with the required libraries listed below.
  • libpq (e.g. libpq3-7.3.4-2mdk.i586.rpm)
  • proj (e.g. proj-4.4.7-1mdk.i586.rpm)
  • libproj (e.g. libproj0-4.4.7-1mdk.i586.rpm)
  • libgdal(e.g. libgdal0-1.1.9-2mdk.i586.rpm)
When I search for the libraries at www.rpmfind.net (i.e. “libpq”) a huge list of different versions comes up. Which ones are the correct ones for my situation? Will the ones created for Mandrake work on my Fedora machine?
Thanks in advance.
Steve
I am attempting to get GRASS 5.7 to run on my Fedora machine. I loaded the binary release and it is have some problems finding certain libraries...what's new. Anyhow, Hamish has graciously provided me with a list of required packages (for RH 9) and I have managed to track down most of them. But I've had some trouble finding the postgresql-odbc package. I am confused, because I have been able to track down postgresql-odbc-6.5.3-6.LS1.i386.rpm, postgresql-odbc-7.0.2-18.2_imnx1.i386.rpm and postgresql-odbc-7.1-1..LS1.i386.rpm. However, I get the impression from the PostgreSQL mirror sites that the official ODBC driver is psqlodbc-07.03.0200. What should I use? Does it matter?
Steve
I have loaded GRASS 5.7 on my computer running Fedora Core 1. It won't
below.
   * libpq (e.g. libpq3-7.3.4-2mdk.i586.rpm)
   * proj (e.g. proj-4.4.7-1mdk.i586.rpm)
   * libproj (e.g. libproj0-4.4.7-1mdk.i586.rpm)
   * libgdal(e.g. libgdal0-1.1.9-2mdk.i586.rpm)
I take it this is a pre-compiled binary?
Note the "mdk". These are Mandrake RMPs, not Redhat/Fedora. :confused:
Download & build the CVS versions of PROJ.4 and GDAL and install into
/usr/local/.
see http://www.remotesensing.org/projects/hosted.php
When I search for the libraries at www.rpmfind.net (i.e. "libpq") a
No idea.
FWIW, this is what was needed for redhat 9:
use "rpm -q PACKAGE" to test, then "rpm -Uvh PACKAGE-1.2.3-4.i386.rpm" to install..
postgresql postgresql-odbc postgresql-server postgresql-devel
unixODBC unixODBC-devel
lesstif lesstif-devel
blas
lapack
readline
libjpeg
libjpeg-devel
libtiff libtiff-devel libpng libpng-devel tk XFree86-Mesa-libGL2 XFree86-Mesa-libGLU
XFree86-devel2 gdbm-devel postfix freetype-devel
You might get lucky, but I wouldn't count on it.
good luck,
Hamish
postgresql-odbc-7.2.5-1.i386.rpm is on disc 2 of the Redhat 9 release.
I don't know if that version would install on a Fedora system; but after
a quick look, there seems to be an official current version for Fedora:
http://fedora.redhat.com/projects/package-list/
postgresql-odbc 7.3 PostgreSQL ODBC driver.
You can download it here:
http://download.fedora.redhat.com/pub/fedora/linux/core/1/i386/os/Fedora/RPMS/postgresql-odbc-7.3-4.i386.rpm
Hamish
