[GRASSLIST:3304] Re: how to interpolate a raster?
leo.lami@katamail.com wrote:
> I'd like to smooth or interpolate a raster but I don't know how to do it.
> I tried with r.surf.idw but the result is not good for me.
> Are there other metods more flexible?
One alternative is to convert the raster to a sites file with
r.to.sites then use s.surf.rst.
Would you like to smooth an already done raster which is not very smooth without changing the resolution or with changing the resolution or would you like to interpolate a set of point (sites) data to get an estimation of the values between them?
In the first case you can use r.mfilter or r.mapcalc's neighborhood modifier. As far as I know r.mfilter does not handle floating point values.
In the second and third case just follow Glynn's suggestion. Or for a more in depth analysis you can use Gstat or R's geostatistic and spatial interpolation packages.
Miha
_________________________________________________________________
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*. http://join.msn.com/?page=features/virus
>it.
Miha
r.neigbors worked for me (the tension was set too high on my DEM, creating
'waves' from the contour lines).
Dave
