[GRASSLIST:332] gis.h problem
Hei,
I have GRASS 6 installed, but I can’t seem do have GIS library
$ gcc main.c
main.c:8:17: error: gis.h: No such file or directory
Why does this happen?
What must I do ?
Thanks
Ana Soares wrote:
I have GRASS 6 installed, but I can't seem do have GIS library
$ gcc main.c
What must I do ?
GRASS doesn't install headers into the system header directories (e.g.
/usr/include), but into the GRASS directory hierarchy (e.g.
/usr/local/grass6/include). You need to use a -I switch to specify the
location, e.g.
  gcc -c -I /usr/local/grass6/include main.c
GRASS is quite a complex package, and may be quite hard to use if you
are new to C programming.
Yes but now I have another problem !
This works fine :
gcc -c -I /usr/lib/grass/include main.c
But :
$ gcc -o prog main.o
main.o: In function main': main.c:(.text+0x26): undefined reference to G_gisinit’
collect2: ld returned 1 exit status
OR
$ gcc -I /usr/lib/grass/include -o prog main.o
is no good… :-S
---------- Forwarded message ----------
Date: 23/03/2006 13:48
Subject: Re: [GRASSLIST:332] gis.h problem
To: Ana Soares <tiobrothercamarada@gmail.com>
Cc: grasslist@baylor.edu
$ gcc main.c
What must I do ?
GRASS doesn’t install headers into the system header directories (e.g.
location, e.g.
Glynn Clements < glynn@gclements.plus.com>
This works fine :
But :
main.o: In function `main':
main.c:(.text+0x26): undefined reference to `G_gisinit'
You need to link against the GRASS libraries, e.g.
  gcc ... -L/usr/local/grass6/lib -lgrass_gis
hallo,
try to look at r.example and v.example modules. IMHO this is the best
way, how to start
jachym
On Thu, Mar 23, 2006 at 11:39:36AM +0000, Ana Soares wrote:
Hei,
$ gcc main.c
What must I do ?
Thanks
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
