[GRASSLIST:337] a huge matrix ?
Hello
I have a huge matrix containing 7 column and 10500 rows.
Each columns stand for different maps. Each rows represent "unique"
combinations of catagories of maps and probability values
of each row.
Something like:
              map1 map2 map3 ... prob
1 cat1 x x x x
2 cat2 x x x x
10500 .
So I have 10500 if-clause to create a probability map.
I tried r.mapcalc (as from a text file) but grass gave "stack overflow" error.
Is there anyone making suggestions ?
thanks in advance
Ahmet Temiz
TURKEY
______________________________________
Scanned and protected by Inflex
http://pldaniels.com/inflex
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
of each row.
Something like:
1 cat1 x x x x
2 cat2 x x x x
10500 .
error.
I'm not surprised.
You need to describe your problem in more detail; it isn't clear what
you are trying to calculate.
Matlab or Octave(free) may be more appropriate for your analysis.
Is it possible to re-orient your method to do 10500 iterations of 7
if-then statements?
Hamish
of each row.
Something like:
1 cat1 x x x x
2 cat2 x x x x
10500 .
overflow" error.
of each row.
Something like:
1 cat1 x x x x
2 cat2 x x x x
10500 .
I'm not surprised.
Thank you for your interest
You wanted to know the problem in more detail:
what I did:
1- using r.stat command I produced a text file for statistical calculations
2- using R statistical package I produced probability results of each map's for each categories.
it means 7 columns of maps 10500 rows plus probability of each combination. Actually it is a contingency table. Any data in table (matrix) is resulting from unique combination of maps and their
categories.
3- I want to port these results to grass to create a map (of landslide susceptibility map) . Firstly I thought I used r.mapcalc with piping from text file. But because text file contains a huge matrix that is made up of 10500 if statement (for same number of rows) process failed.
I attached a part of text file after modifying for r.mapcalc. you see all ifs are unique.
might it be a solution, if I divide the text file to smaller parts and produce diffent maps , then add these maps with r.patch (or r.mapcalc) ?
kind regards
(attachments)
pr2.gz (925 Bytes)
>>of each row.
>>Something like:
>>1 cat1 x x x x
>>2 cat2 x x x x
>>10500 .
>>error.
>I'm not surprised.
what I did:
categories.
all ifs are unique.
OK, so: each line is a rule; for each pixel you scan the list of rules
to find the first match, then output the associated result. Right?
The most straightforward approach (although not particularly
efficient), would be to use an iterative approach, i.e.
  n=0
  last='null()'
  while read a1 a2 a3 a4 a5 a6 a7 a8 ; do
    result=pr2.pass$n
    r.mapcalc "$result = if (f28geo5==$a1 && f28slpcat==$a2 && f28concavity==$a3 && n_facing==$a4 && road_bas==$a5 &&str_buf==$a6 && f28f4==$a7, $a8, $last)"
    last=$result
  done < rules.txt
where rules.txt looks like:
  21 6 1 1 1 1 0 701.22
   7 4 2 1 1 2 1 702.06
Alternatively, you could combine this with your initial approach, only
matching a limited number of rules on each pass, and using several
passes.
However, I note that there seem to be very few possible values for
most of the maps. In that case, a far more efficient approach would be
to:
1. Reclass each input map so that all of the significant categories
are consecutively numbered from zero (0,1,2,3,...); any insignificant
categories would be merged into the last category.
2. Compute a composite map, using e.g.
  composite = f28geo5 + 22 * (f28slpcat + 9 * (f28concavity + 3 * ...
where the numbers are the total number of categories in the preceding
map.
3. Assign the values as labels for the composite categories.
4. Use "@map" in r.mapcalc to use the label instead of the category.
Perhaps you can use the r.infer
The probability values can be inserted in the category labels, and
recovery by r.mapcalc (map = @infer).
I do not know if is functional with so much rules.
IFMAP map1 cat#
ANDIFMAP map2 cat#
ANDIFMAP map3 cat#
THENMAPHYP 1 probability2
IFMAP map1 cat#
ANDIFMAP map2 cat#
ANDIFMAP map3 cat#
THENMAPHYP 2 probability2
> >>of each row.
> >>Something like:
> >>1 cat1 x x x x
> >>2 cat2 x x x x
> >>10500 .
> >>error.
> >I'm not surprised.
> what I did:
> categories.
> all ifs are unique.
  n=0
  last='null()'
    result=pr2.pass$n
    last=$result
  done < rules.txt
passes.
to:
map.
Sandro Klippel <sandro.klippel@talha-mar.com.br>
talha-mar projetos ambientais
Conselheiro d'Avila 190
Porto Alegre,RS 91040-450
+55 (51) 3344-7451
w w w . t a l h a - m a r . c o m . b r
I'm not sure that you found an answer to this yet, Ahmet - if you did,
please ignore this suggestion:
1) use r.mapcalc to create an integer combined index for the combinations
of your raster layers:
    tmp1 = mapa*10 + mapb
    tmp2 = tmp1*10 + mapc
or some such way of generating an integer index differentiating the
different types. If there are raster values outside 0-9, maybe reclass
first, or use 100 instead of 10 to left shift the index where there are
10-99 discrete values.
2) In R, generate the same integer index, and make a data frame with the
integer index in one column, and the probabilities in another.
3) Use the R/GRASS interface (or r.stats -1 and scan()) to move either the
whole of your index raster, or more likely tiles made by changing the
GRASS region, to R.
4) in R, use vectorised lookup to search for the probability value given
the index value - match() is fast and powerful (I haven't checked this,
but do use match() in other code - it will probably work much better on
tiles than your big raster) and assign the probability values to a new
vector.
5) move this vector back to GRASS as FCELL or DCELL. If you are tiling,
finish off by patching the tiles back together.
6) My guess is that the tiling, import, matching, and export can all be
done in a loop within R.
Rationale: the combined index avoids all the if statements - 11K if's is
rather a lot! I did think about pushing it all out say to postgresql and
using SQL (one table of RHS raster values, one table of lookups) but there
were still seven fields on each side to index on, so it seemed at least
worth trying to combine them automatically by left shifting (probably not
the right word) and addition, which are cheap operations in r.mapcalc.
Please let me know how you tackled this problem, your solution will have
general interest, and should be in the general GRASS knowledge base. I can
expand on this off-list if it is of any use.
Roger
> >>of each row.
> >>Something like:
> >>1 cat1 x x x x
> >>2 cat2 x x x x
> >>10500 .
> >>error.
> >I'm not surprised.
> what I did:
> categories.
> all ifs are unique.
  n=0
  last='null()'
    result=pr2.pass$n
    last=$result
  done < rules.txt
passes.
to:
map.
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
I'm not sure that you found an answer to this yet, Ahmet - if you did, please ignore this suggestion:
1) use r.mapcalc to create an integer combined index for the combinations of your raster layers:
or some such way of generating an integer index differentiating the different types. If there are raster values outside 0-9, maybe reclass first, or use 100 instead of 10 to left shift the index where there are 10-99 discrete values.
2) In R, generate the same integer index, and make a data frame with the integer index in one column, and the probabilities in another.
3) Use the R/GRASS interface (or r.stats -1 and scan()) to move either the whole of your index raster, or more likely tiles made by changing the GRASS region, to R.
4) in R, use vectorised lookup to search for the probability value given the index value - match() is fast and powerful (I haven't checked this, but do use match() in other code - it will probably work much better on tiles than your big raster) and assign the probability values to a new vector.
5) move this vector back to GRASS as FCELL or DCELL. If you are tiling, finish off by patching the tiles back together.
6) My guess is that the tiling, import, matching, and export can all be done in a loop within R.
Rationale: the combined index avoids all the if statements - 11K if's is rather a lot! I did think about pushing it all out say to postgresql and using SQL (one table of RHS raster values, one table of lookups) but there were still seven fields on each side to index on, so it seemed at least worth trying to combine them automatically by left shifting (probably not the right word) and addition, which are cheap operations in r.mapcalc.
Please let me know how you tackled this problem, your solution will have general interest, and should be in the general GRASS knowledge base. I can expand on this off-list if it is of any use.
Roger
of each row.
Something like:
1 cat1 x x x x
2 cat2 x x x x
10500 .
I'm not surprised.
what I did:
categories.
n=0
last='null()'
  result=pr2.pass$n
  last=$result
done < rules.txt
passes.
to:
map.
Thank you sir
You know my study from previous messages.
I had several good suggestions from so many kind people including you.
I am going to try them especially grass/R interface.
Firstly I want to know if it is correct to use the formulas in the attachment.
I divided the file to 7 according to probability values to handle with r.mapcalc.
(Beforehand I had sorted the data according to probability vales by a spreadsheet). Then I used
r.mapcalc as in attachment. [I would reclassify in the grass anyway according to
probability values as high, moderate and low . Because of a large text file . I did division
(reclassifying) in input level ( or in text file level)].
But I hesitated on addition of each if expression in r.mapcalc. It must be okey. Because
each if expressionsare unique, they represent different areas. So added values don't coincide each other.
Could you please tell me firstly whether my approach is correct or false. And why ?
kind regards
(attachments)
pr2.gz (925 Bytes)
of each row.
Something like:
1 cat1 x x x x
2 cat2 x x x x
10500 .
I'm not surprised.
what I did:
categories.
n=0
last='null()'
  result=pr2.pass$n
  last=$result
done < rules.txt
passes.
to:
map.
Thank you for your help
Firstly I intend to try your iterative way.
In that, doesn't n have any increament ?
something like n=n+1 in the loop.
If so,Doesn't it mean creating a new map - totally 10500 map- in every iteration
regards
> n=0
> last='null()'
> result=pr2.pass$n
> last=$result
> done < rules.txt
Yes; I had missed out a line; in bash, you can use:
  n=$((n + 1))
In shells which don't have built-in arithmetic, you can use "expr",
e.g.
  n=`expr $n + 1`
iteration
Yes. However, you only need to keep the last map; the rest can be
removed, e.g.
  if [ $n -ge 2 ] ; then
    g.remove rast=pr2.pass$((n - 2))
  fi
> n=0
> last='null()'
> result=pr2.pass$n
> last=$result
> done < rules.txt
iteration
Not sure if this is what you are after, but as a general iterative bash scripting template:
n=0
r.mapcalc patchmap="null()"
  echo "Pass $n .."
  r.mapcalc ...
  r.patch out=patchmap in=patchmap,pr2.pass$n (?? r.mapcalc sum=sum+new ..)
  g.remove rast=pr2.pass$n
  n=`expr $n + 1`
done
actually for that n isn't needed, but still a good idea.
Hamish
n=0
last='null()'
  result=pr2.pass$n
  last=$result
done < rules.txt
n=0
echo "Pass $n .."
r.mapcalc ...
n=`expr $n + 1`
done
Hamish
thank you
adding maps then deleting maps created previously is very good idea to maintain harddisk space.
kind regards
