Radim (or others),
I am trying to use eps files with triangles as site icons in ps.map with
the size_att command. Do I understand correctly that size_att works in
proportion to the number of pixels in the eps file ?
Moritz
Radim (or others),
Moritz
On Tuesday 10 June 2003 18:19, Moritz Lennert wrote:
Radim (or others),
EPS is scaled by size_att, I think. If the original size of icon is 5mm and
size_att 2, the size of icon in output map should be 10mm.
Radim
Radim (or others),
proportion to the number of pixels in the eps file ?EPS is scaled by size_att, I think. If the original size of icon is 5mm
and
So that means the height of th triangle, or the length of its sides, will
be multiplied ?
Moritz
On Wednesday 11 June 2003 09:25, Moritz Lennert wrote:
>> Radim (or others),
> and
> size_att 2, the size of icon in output map should be 10mm.So that means the height of th triangle, or the length of its sides, will
be multiplied ?
Yes, but multiplied by 'size * size_att' to be precise, I hope.
Radim
