[GRASSLIST:3415] Snapping thershold
Is there a way to set the snapping and digitizing thershold relative to the zoom (scale) of the digitized map? I mean to change the snapping threshold with zooming in and out in v.digit.
The last time when I was digitizing I had the impression the snapping in v.digit behaved so. Is it possible it changed to an absolute value? How would I correct this?
Another question:
Where do the temporary files of GRASS 5.3 reside? Is it the .tmp directory in the location directory or there anything else?
Thanks, Miha Staut
_________________________________________________________________
Tired of spam? Get advanced junk mail protection with MSN 8. http://join.msn.com/?page=features/junkmail
On Saturday 15 May 2004 20:23, Miha STAUT wrote:
In 5.7 (v.digit -> settings -> settings) you can select threshold either
in screen pixels or in map units.
Radim
Usually:
[GISDBASE]/[LOCATION_NAME]/[MAPSET]/.tmp
but sometimes it can put files in /tmp (those need to be updated to
use g.tempfile, usually contributed scripts)
You can remove any temporary files with the following command:
$GISBASE/etc/clean_temp
(e.g. before switching mapsets with 'g.gisenv set="MAPSET=foo"')
Hamish
