I'm looking for suggestions as to automating the export process. I want to batch process an export job of several hundred orthorectified raster maps form grass57, so that others can digitize them in ARC-GIS. I'd appreciate hearing approaches that folks have use for this kind of work?
Kirk
I use a shell script for things like that. For example,
1. create a list of raster to export in a text file:
ls /LOCATION/MAPSET/cellhd > list.txt
2. create a script "export.sh" something like:
while read f
do
g.region rast=$f
r.out.tiff -t input=$f output=$f
done
Hi Kirk,
Speaking of experience, you don't want to run a long script in a current GRASS
session, unless you have plenty of time before you and no need of GRASS
meanwhile. The easiest is to run an alternate session. From various info
gathered on the mailing list, I came with this small script (a complete
ripoff from Glynn Clements <glynn.clements@virgin.net>): you have to define
the location and mapset (existing ones) in the first lines, add your export
commands in the third section, and just run the script. That's OK as long as
your export commands remain in the same mapset and that you don't intend to
display anything (else you may run into some troubles).
I guess that the easiest would be to use r.out.tiff for your DOQQs. Just
browse through your rasters, you can access the list in
$GISDBASE/$LOCATION_NAME/$MAPSET/cell
Consider the size of the files if you have a lot of them...
# PUT YOUR EXPORT COMMANDS THERE
Soil & Water Laboratory
Dept. of Biological & Environmental Engineering
Cornell University
ITHACA, NY 14853
Tel: (607)255.2463
