[GRASSLIST:3447] r.in.gdal
I'm trying to import .dem files (I have the grass5.0.3 version), but a
segmentation fault occurs:
        GRASS:~ > r.in.gdal
        OPTION: Bin raster file to be imported
             key: input
        required: YES
        enter option > /usr/local/marta/sud.dem
        You have chosen:
          input=/usr/local/marta/sud.dem
        Is this correct? (y/n) [y]
        OPTION: Band to select (default is all bands)
             key: band
        required: NO
        enter option >
        OPTION: Name for resultant raster map
             key: output
        required: YES
        Enter raster file name
        Enter 'list' for a list of existing raster files
        Hit RETURN to cancel request
        > sud_dem.rast
        <sud_dem.rast>
        OPTION: Name of location to read projection from for GCPs
        transformation
             key: target
        required: NO
        enter option >
        OPTION: Title for resultant raster map
             key: title
          format: "phrase"
        required: NO
        enter option >
        OPTION: Name for new location to create
             key: location
        required: NO
        enter option >
        FLAG: Set the following flag?
            Override projection (use locations projection)?(y/n) [n]
            Extend location extents based on new dataset.?(y/n) [n]
        Segmentation fault
So I tried processing this DEM with the commandline GDAL utilities
instead of the GRASS r.in.gdal command, and in this way it seems working
fine (I have GDAL 1.2.0):
        [root@geomorf2 root]# gdalinfo -mm /usr/local/marta/sud.dem
        Driver: USGSDEM/USGS Optional ASCII DEM
        Size is 935, 1250
        Coordinate System is:
        PROJCS["UTM Zone 33, Northern Hemisphere",
            GEOGCS["WGS 84",
                DATUM["WGS_1984",
                    SPHEROID["WGS 84",6378137,298.257223563,
                        AUTHORITY["EPSG","7030"]],
                    TOWGS84[0,0,0,0,0,0,0],
                    AUTHORITY["EPSG","6326"]],
                PRIMEM["Greenwich",0,
                    AUTHORITY["EPSG","8901"]],
                UNIT["degree",0.0174532925199433,
                    AUTHORITY["EPSG","9108"]],
                AXIS["Lat",NORTH],
                AXIS["Long",EAST],
                AUTHORITY["EPSG","4326"]],
            PROJECTION["Transverse_Mercator"],
            PARAMETER["latitude_of_origin",0],
            PARAMETER["central_meridian",15],
            PARAMETER["scale_factor",0.9996],
            PARAMETER["false_easting",500000],
            PARAMETER["false_northing",0]]
        Origin = (334305.000000,4762665.000000)
        Pixel Size = (90.00000000,-90.00000000)
        Corner Coordinates:
        Upper Left ( 334305.000, 4762665.000)
        Lower Left ( 334305.000, 4650165.000)
        Upper Right ( 418455.000, 4762665.000)
        Lower Right ( 418455.000, 4650165.000)
        Center ( 376380.000, 4706415.000)
        Band 1 Block=935x1250 Type=Float32, ColorInterp=Undefined
            Computed Min/Max=-27.000,2847.900
          NoData Value=-32767
          Unit Type: m
Could someone help me?!?!?
marta
Hello Marta
AFIK, probably your region settings don't are equal to your dem projection.
You can check what region you have with the command g.region.
Maybe you can use:
r.in.gdal -oe input=/usr/local/marta/sud.dem output=sud_dem.rast
the flags -eo means yes to the questions :
and
Have a nice day,
Guillermo
        GRASS:~ > r.in.gdal
             key: input
        required: YES
        You have chosen:
             key: band
        required: NO
        enter option >
             key: output
        required: YES
        > sud_dem.rast
        <sud_dem.rast>
        transformation
             key: target
        required: NO
        enter option >
             key: title
          format: "phrase"
        required: NO
        enter option >
             key: location
        required: NO
        enter option >
        Segmentation fault
        Size is 935, 1250
            GEOGCS["WGS 84",
                DATUM["WGS_1984",
                AXIS["Lat",NORTH],
                AXIS["Long",EAST],
        Corner Coordinates:
          NoData Value=-32767
          Unit Type: m
marta
