[GRASSLIST:3468] need help with a script PS
I've written a handy script to read a Terra-ASTER satellite image into GRASS using gdalwarp and r.in.gdal. However, I am baffled by why it won't work if I enter projection information to georeference the ASTER image into a specified geographic projection.
The script works fine if I don't enter the information. If enter the information, echo the gdal command created by the script, and paste the echo'ed output into the command line, it runs fine. I've tried every permutation I can think of to get gdalwarp to recognize the -t_srs parameter. Obviously, I haven't yet hit on the correct on.
If anyone has a few minutes to look at this, the relevant line is #116 (gdalwarp $GIS_FLAG_q $tgt_srs $srcfile $dstfile). Thanks much for any help.
Michael Barton
(attachments)
r.in.aster (2.77 KB)
Hello Michael
I think it's some kind of quoting problem---there are a lot of " and I didn't completely follow it.
What about changing line 94 from
         tgt_srs="-t_srs "\"$tgt_srs\"
to
         tgt_srs="-t_srs \"$tgt_srs\""
BUT---in wondering why you didn't just use 'g.proj -jf' to get the target co-ordinate system to match that of the current GRASS location, it gave me a good idea for a script to automatically reproject and import an image into GRASS using gdalwarp and r.in.gdal, instead of having to run r.in.gdal on a separate location and then r.proj to re-project the image inside GRASS.
See attached; do you think it is useful?
The main reservation I have about it is that it removes the need for users to think about what they are doing when re-projecting data, e.g. the re-sampling algorithms used in gdalwarp are hidden from the user and they might not be aware of distortion caused at the edge of null areas and
coastlines and things like that. More automation means less thinking about
how exactly you are processing your data and what errors you might be
introducing.
The other possible problem I can see is due to the recently confirmed 'feature' in PROJ whereby if no datum transformation parameters are given in a co-ordinate system description, +towgs84=0,0,0 is assumed and datum transformation performed on this basis. If the input dataset doesn't have
datum information (leading to the above assumption) but the GRASS location does, I suppose there is a chance of shifting errors. Not sure how likely
this is to happen in practice but it could be a problem with this idea.
Paul
(attachments)
r.in.gdalproj (1.52 KB)
