[GRASSLIST:3550] r.fillnulls-s.surf.rst
after compiling 5.3 from cvs, I'm getting this message from r.fillnulls
(I guess it came from s.surf.rst)
Note: Below warnings may be ignored.
Using no segmentation for interpolation as not needed...
Warning: strip exists with insufficient data
ERROR: segmentation parameters set to invalid values: npmin= 300,
segmax= 700
for smooth connection of segments, npmin > segmax (see manual)
ERROR: Input failed
Note: Above warnings may be ignored.
Patching fill data into NULL areas...
r.patch - rfillnulls.r.fillnulls.3320 not found
Filled raster map is: test
This happens when there are less than 800 points so no segmentation
needed. Work is stopped and map is not filled.
Best regards,
Roman
