Hello,
Under peer pressure, I decided to display results in 3D with NVIZ (I run
5.0.0.pre5 on a linux i386). Thanks to the tutorial, I eventually managed to
create a script displaying these maps and outputting a series of .PPM files.
Neat. Except that :
* the exportation seems to be run with image dump (screen capture). You
imagine the result, if I move windows other nviz or change of desktop to
check my emails. Is it one of the features that has been corrected in 5.0.2
? Is there a workaround (apart leaving the nviz window on the top, decreasing
the pause time to speed up the process, and not checking my emails) ?
* I now have nice '.RGB' or '.PPM ' files (well, the ones that are usable),
weighting each several hundreds of kb, if not several Mb, which causes a
problem of space. Is there a trick to run a conversion command in the nviz
script ? I'd like to store the pictures as .PNG, as I can always transform a
PNG in PPM during the creation of a MPEG (quality is less important than size
in my case), and cannot really wait for the exportation to end before startng
the conversion.
Apart from this:
* I'm embedding the nviz script in a larger bash script,as a here document.
Everything runs pretty smoothly (after escaping the $ of course), but how do
I quit nviz (still staying in the parent script) ?
*I'm afraid I missed something: can I change the state in a loop ? That'll
allow me to get a 'moving viepoint' animation, scripted.
* Is there any howto describing how to write a state, or, what's the meaning
of each line/variable in the state file ? I could figure some of them, but
hav no idea for the others.
Sorry, that's a lot of question at once, but any suggestion would be more than
welcome.
Thanks
P.
Soil and Water Laboratory
Biological and Environmental Engineering Department
Cornell University
Riley-Robb Hall
ITHACA, NY 14853 - USA
