[GRASSLIST:3628] error cannot create table on v.in.ogr command
hi listers..,
Now I'm work with grass 5.7 and data from
ArcView(shape file).
A few minute ago, I want to import my data (.shp) in
grass with the attribute in database.
I use postgresql for database.But there is error while
I execute v.in.ogr command.
command that I execute and the error:
v.database driver=pg database=testdb schema=postgres
v.in.ogr dsn=/mnt/win/dewa/shp_file/administrasi/
output=administrasi layer=administrasi min_area=0.0001
type=boundary snap=0.001 -c
PROJ_INFO file not found for location latihan
PROJ_UNITS file not found for location latihan
Projection of input dataset and current location
appear to match.
Proceeding with import...
Layer: administrasi
DBMI-Postgres driver error:
Cannot execute:
create table postgres.administrasi (cat integer, ID
integer, KECAMATAN varchar ( 20 ), LUAS_AREA double
precision, BANGKITAN integer, TARIKAN integer)
ERROR: Namespace "postgres" does not exist
ERROR: Cannot create table: create table
       integer, ID integer, KECAMATAN varchar ( 20 ),
LUAS_AREA double precision,
can you help me to solve my problem,please?
thank's for your help before.
regard,
Didit
__________________________________
Do you Yahoo!?
Friends. Fun. Try the all-new Yahoo! Messenger.
http://messenger.yahoo.com/
schema option in v.database means the name of a schema
in Postgres database. Schemas are supported only in latest
versions of Postgres. Most probably you don't want to use
schemas at all, in that case, unset schema:
If you realy want to use schemas, the schema 'postgres'
must exist in your database 'testdb'.
Radim
On Tuesday 08 June 2004 20:26, Didit Ahendra wrote:
hi listers..,
appear to match.
Layer: administrasi
Cannot execute:
regard,
Didit
Do you Yahoo!?
