Hello everybody,
I have installed cygwin and grass5.0.2 under windows2000, but when I use the command grass5 -tcltk, a popup dialog said "libX11.dll not found". What is wrong? In fact, I can not find libX11.dll in my computer.
Hello everybody,
computer.
For a start, you need to install Cygwin's XFree86 packages in order to
use tcltkgrass or NVIZ.
Also, /usr/X11R6/bin needs to be in Cygwin's PATH setting.
