[GRASSLIST:3651] gmake5 in grass57
Hi
i successfully installed grass5.7, with the sources of 5.3 (after working with grass 5.0.3) on a suse8.2.
Now i tried to run own code with grass5.7 as i did with in 5.0.3 using the gmake5 for compiling,
but i cannot find a similar gmake5-file (as in 5.0.3) for the grass5.7.
My questions are now:
- Does i have to install grass5.3 for working with own code addressing tools in grass5.7 (or is just downloading the sources and telling 5.7 where it is enough)?
- how can i get a appropriate gmake5 for grass5.7?
Thanks Dani
grass5.7.
tools in grass5.7
you only need 5.3 for the make 'mix step' .. after that you don't need
it anymore.
use 'make' instead; copy a Makefile from another similar module & modify
to suit.
Hamish
Hi
i renamed the Gmakefile to Makefile (cause i got no other Makefile):
CC=g++
# include of dirs, e.g.gis.h is in ...
CFLAGS=-g -Wall
EXTRA_CFLAGS=-I /data/gis/nfp48/nfp48/ipodlas0.1/grass/grass57/grass57/include
# including of libs: e.g. D_ are in DISPLAYLIB
# order of libs: important -> DISPLAYLIB before RASTERLIB before GISLIB,etc
LIBES=$(DISPLAYLIB) $(RASTERLIB) $(IMAGERYLIB) $(VASKLIB) \
   $(GISLIB) $(DATETIMELIB) $(CURSES) $(XDRLIB) $(MATHLIB) $(SEGMENTLIB)
DEPLIBES=$(DEPIMAGERYLIB) $(DEPGISLIB) $(DEPVASKLIB) $(DEPVASK)
OBJ=main.cc plotRasterMap.cc
all: plotRasterMap
#with -g: gdb enabling option
plotRasterMap: $(OBJ) $(LIBES) $(DEPLIBS)
   $(CC) $(LDFLAGS) -g -o $@ $(OBJ) $(LIBES) $(DEPLIBES) $(LIST): global.h
$(LIBES): #in case of library change;i.e.they must be here,
$(DEPLIBS):
# to clean up
.PHONY: clean
clean:
   rm *.o *~ ~* *@ \#*
and get errors now starting with:
... undefined reference to `G_gisinit'
(going on with similar errors concerning G_ and R_ functions)
I guess this means either a library is missing or the order is wrong in LIBES, but i cannot figure out what.
Thanks dani
> to suit.
That won't work. The syntax of a 5.7 Makefile is completely different
to that of a Gmakefile.
Copy a Makefile from a similar module and modify it.
to suit.
Hi thanks for your advice,
but i didn't succeed to move a step forward:
'Copy a Makefile from a similar module and modify it.'
a makefile from grass57 module? Like e.g. the display/d.erase/Makefile? (there I'm stuck with the include-line and its further invocations (Module.make))
However, i tried with different version of Makefiles
(e.g.
CC=g++
CFLAGS=-c -Wall
EXTRA_CFLAGS=-I /data/gis/nfp48/nfp48/ipodlas0.1/grass/grass57/grass57/include/
# collection of dependencies
OBJ=main.o plotRasterMap.o
main.o: main.cc plotRasterMap.h
plotRasterMap.o: plotRasterMap.cc plotRasterMap.h
or with
#Path to header-files
INCLUDE=-I/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass57/grass57/include/
#Path to librarys
LIBS=-L/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass57/grass57/lib
the answer is allways
g++ -g -o plotRasterMap -I/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass57/grass57/include/ main.cc plotRasterMap.cc
How can i invoke GRASS-functions?
Thanks Dani
> > > to suit.
Yes. To simplify matters, use a Makefile from a module which has a
similar set of dependencies. E.g. if you need to use the
raster/display libraries, use a Makefile from one of the display/d.*
modules.
(Module.make))
What do you mean by "stuck"? All modules (programs) need the line:
  include $(MODULE_TOPDIR)/include/Make/Module.make
This includes all of the common definitions, along with the settings
which are generated by the configure script.
In earlier versions, the gmake script concatenated a set of files (one
of which was the Gmakefile) to produce the final Makefile. In 5.7, we
just use the "include" directive instead.
None of which look remotely like any of the 5.7 Makefiles, which
suggests that you aren't copying an existing Makefile.
