[GRASSLIST:3709] gnu software for digitizing
Hi
I'm working with my pupils with GRASS (developping several DEMs) and they have problems because v.digit is not as friendly as is MapInfo (as a first module we worked with it)
Is possible to work whit another gnu-program that supports raster images and layers to digitize contours and export them (e.g. as *.dxf) into GRASS?. I tried with The GIMP, but it don't exports in vector format; also tried with QCad, but it has not support for raster layers,...
Can anybody help us?...
_________________________________________________________________
Reserva desde ahora tus vacaciones en MSN Viajes. Más cómodo, más barato y más opciones. http://www.msn.es/Viajes/
Hi
I understand. I had the same problem this semester but finally my
students get familiar with v.digit. it just a problem of changing habits
common to win. There are some helpful arguments which I used:
1. GRASS is a free software so they can use it at home computers without
any restrictions
2. There are some much advanced things in GRASS comparing with mapinfo
like polygon topology (direct labeling of polygons) and some programs
which speeding up digitizing like e.g.: v.spag, v.trim
In my opinion, after a little training, digitizing in v.digit is much
faster than mapinfo since all menus are available via 3 buttons only
Check OpenEV. from remotesensing.org There is an module for drawing but
I have never tried this.
Best regards
Zbigniew
I would give the JUMP program suite a try.
It is very nice software written in Java and completely free.
It has tools for creating vector maps that exceed MapInfo in
many ways and can output Shape files or load/save from a
PostGIS SQL database.
However, if you want to use raster layers, you
have to set up an WebGIS server, such as the UNM Map Server
(http://mapserver.gis.umn.edu/index.html) and connect to it from JUMP.
JUMP does, unfortunately, not support direct loading of
raster layers from file (as far as I know).
http://www.jump-project.org/
Benjamin
On Fri, 18 Jun 2004 11:50:25 +0000
"juan pablo perez" <valdentro@hotmail.com> wrote:
Hi
Are you trying the v.digit from 5.0/5.3 or 5.7? The version in 5.7 has a
totally new GUI and is much much much better.
If you are using 5.7, and it still isn't good enough, please add any
suggestions to the wish list so it can improve with time:
http://grass.ibiblio.org/bugtracking/wish.html
Hamish
  you can try g3data also, perhaps it is useful for that purpose. I have
necer udsed it.
   D.
Hi
they
first
any restrictions
and
Best regards
Zbigniew
This email was sent using http://cafemail.edacafe.com .
On Sun, Jun 20, 2004 at 04:51:48PM -0400, DrakeGis wrote:
>> Hi
>> they
>> first
Did you look at the new v.digit in GRASS 5.7.0?
http://mpa.itc.it/markus/grass57/vdigit_grass57.jpg
(digiziting a geocoded hand-drawn field map)
