[GRASSLIST:3721] Re: Error in NVIZ
On Jun 18, 2004, at 10:01 PM, Multiple recipients of list wrote:
hello
I have newly installed grass57.
Firstly I wanted looked at NVIZ
Although it worked in grass53, it seemed there was an error in
grass57.
In GRASS 5.7, there is a bug that prevents it from starting from the autogenerated dialog box that appears when you type nviz on the command line. You can either start nviz from the command line with nviz -q (this switch starts nviz without loading any maps at startup) or start it from the 'Display/nviz' menu item (which does the same thing). Then you can add raster and vector layers to nviz via the surface (for rasters), vector (currently supports lines only), and sites (for vector points) panels.
Michael Barton
here is the error:
Adding panels from /usr/local/grass5.7.cvs-i686-pc-linux-gnu-15_06_2004/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
child killed: segmentation violation
   while executing
"exec /usr/local/grass5.7.cvs-i686-pc-linux-gnu-15_06_2004/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5.7.cvs-i686-pc- linux-gnu-15_06_2004/etc/nviz2.2/sc..."
   ("eval" body line 1)
   invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
   invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo ..."
   (file "/usr/local/grass5.7.cvs-i686-pc-linux-gnu-15_06_2004/bin/nviz" line 16)
does anyone tell me why ?
kind regards
Ahmet Temiz
_____________________________
C. Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
WWW - http://www.public.asu.edu/~cmbarton
Phone: 480-965-6262
Fax: 480-965-7671
hello
grass57.
Michael Barton
here is the error:
Adding panels from /usr/local/grass5.7.cvs-i686-pc-linux-gnu-15_06_2004/etc/nviz2.2/ scripts
Nv_(panels)
toplevel made
   while executing
"exec /usr/local/grass5.7.cvs-i686-pc-linux-gnu-15_06_2004/etc/nviz2.2/ NVWISH2.2 -f /usr/local/grass5.7.cvs-i686-pc- linux-gnu-15_06_2004/etc/nviz2.2/sc..."
   invoked from within
   invoked from within
"if {$argv == ""} {
#no arguments
kind regards
Ahmet Temiz
Phone: 480-965-6262
Fax: 480-965-7671
thank you for your interest
I tried nviz -q from command line.
The problem still exists in grass57 (binary).
when I tried menu item, nothing has changed.
PS. nviz works in grass53.
kind regards
Ahmet Temiz
TURKEY
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
