[GRASSLIST:3732] grass++
hello, i try to compile the grass++ library but i get the following messages:
ueberflieger:/usr/local/lib/grass++0.2 # ./configure --with-grass=/home/
sabine/diss/grassdata/
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
configure: creating ./config.status
config.status: creating Makefile
ueberflieger:/usr/local/lib/grass++0.2 # make
Makefile:4: /home/sabine/diss/grassdata//../include/Make/Platform.make: Datei
oder Verzeichnis nicht gefunden
make: *** Keine Regel, um »/home/sabine/diss/grassdata//../include/Make/
Platform.make« zu erstellen. Schluss.
does anyone know, how i can handle this message? thank you, sabine
