William, Eric, Carlos, Hamish, Markus:
Thanks erverybody for your suggestions,
I used GeoTIFF WRS-2 tiles from GLCF, so I have probably wasted a fair amount of time filling voids etc. However, as Hamish would say, not really a waste of time cause I learned something on r.fillnulls and r.resamp.rst.
Hamish: thank you for the hint on the vector general question. I have been playing aroung with v.type for quite a while, then I decided to ask for help. Good, for two reasons. First, I got to know about srtm2. Second, now I know it is possible to build area topology from lines.
Thank you all again and if anybody knows the correct command to add centroids to boundaries, please let me know.
Luigi
P.S. While I was writing this message, Markus filled the gap: THANKS!!!
On Sun, 26 Mar 2006 16:36:32 +1200
Hamish <hamish_nospam@yahoo.com> wrote:
Following the GRASSNews_vol3 article on SRTM import, I was trying to sharpen coastlines using GSHHS shapefiles. However, the imported GSHHS
vectors are just lines and not areas. Therefore I do not know how to generate a raster MASK, because there is no area for v.to.rast to produce a filled raster coverage.
others have mentioned the new SRTM v2 so I'll leave that, but for the
general vector how-to question:
An area is made up of a boundary and a centroid, so two steps are
needed:
# convert lines to boundaries
v.type line,boundary
# add centroids v.category op=add # ?!!!
This second part I know possible, but I forget the correct command.
Maybe it is v.build or v.clean?
Hamish
INFINITO ADSLFLAT 4 MEGA: SOLO 27,90 EURO AL MESE IVA INCLUSA IP STATICO, BANDA GARANTITA 256Kbps ANTIVIRUS E FIREWALL INCLUSI NEL PREZZO
http://adsl.infinito.it
