[GRASSLIST:3757] Re: v.digit and raster as background
On Jun 27, 2004, at 10:01 PM, Multiple recipients of list wrote:
Date: June 27, 2004 3:45:25 AM MST
To: "GRASSLIST(engl)" <GRASSLIST@baylor.edu>
Subject: [GRASSLIST:3755] Re: v.digit and raster as background
On Sunday 27 June 2004 12:35, Martin Wegmann wrote:
already found a mistake -- changed vector names, now it should be fine
Actually, it probably won't work from the autogenerated GUI. At least it never has on my Mac. This is another case of the autogenerated GUI not parsing arguments with spaces. In this case, the bgcmd=d.rast mapname won't work because there is a space. This does work from the command line. It also works if you add a raster command from within the v.digit settings dialog after starting v.digit.
Michael Barton
# digitize a new vector and using the first vector and the raster image as
background
d.erase # clear monitor
v.digit -n map=name_of_second_vector bgcmd="d.rast
map=name_of_your_raster; d.vect=name_of_new_vector"
#v.digit GUI appears and the layer defined in the "bgcmd=" settings are
displayed in the background. The "bgcmd=" settings have to be seen as a
series of commands separated with ";", therefore the last command "d.vect"
displays the previously created vector on top of the raster image.
Martin
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
