David,
When I use the correct syntax:
v.in.ascii input=/home/adams/locations.txt output=locs_new format=point fs="|" columns='x double precision,y double precision,z double precision,id int' x=1 y=2 z=3 cat=0
I get a memory fault with GRASS 6.1CVS; again, with GRASS 6.0.2 I have no problems.
Tom
David Finlayson wrote:
I recall there have been discussions about this (GUI) issue before. If
this is still in the latest CVS version, report it as a bug. Mike has
been working hard on the GUI to fix these things.David
On 3/24/06, Thomas.Adams@noaa.gov <Thomas.Adams@noaa.gov> wrote:
David,
Yes, you are correct. But, understand that I simply copied and pasted from the GRASS GUI --
I did not do any
editing. I'll try with the correct syntax tomorrow... actually, I have been through this before.
The problem is
(really) that using v.in.ascii through the GRASS GUI, still fails for me with GRASS 6.1CVS, but
works with GRASS
6.0.2.Thanks again for your help...
Tom
----- Original Message -----
From: David Finlayson <david.p.finlayson@gmail.com>
Date: Friday, March 24, 2006 3:41 pm
Subject: Re: GRASS 6.1CVS v.in.ascii problemThis command has two syntax errors in it:
format=point> fs=| 'columns=x double precision,y double precision,z
double> precision,id int' x=1 y=2 z=3 cat=0it should be:
format=point> fs="|" columns='x double precision,y double
precision,z double
Note the position of the quotes in both the "fs" and the "columns"
options. I don't think you can use a pipe character without quoting it
(I don't know about single or double quotes. Try both) and the columns
argument has the quote in the wrong place altogether.- David
On 3/24/06, Thomas Adams <Thomas.Adams@noaa.gov> wrote:
David,
Very interesting. Here are the facts:
Using a RedHat Linux system
Both v.in.ascii and v.proj (from lat-long location to LCC
location) work
fine with GRASS 6.0.2 built from source.
Using GRASS 6.1CVS (dated 2006-03-18) built from source v.proj (now)
works, but did not with the 2006-03-04 CVS build; v.in.ascii does
NOT> work -- I get errors:
WARNING: Unparsable LatLong value found:
-80.04916667|39.56444444|860|49450586
-84.82388889|38.705|0|49450588
-88.50583333|39.35944444|0|49450598
-81.20388889|39.56305556|0|49450600
-82.17777778|41.34416667|0|49450616
-84.95972222|39.73305556|0|113805417
-82.92166667|40.35666667|901|113805418
-85.15833333|39.57361111|850|113805424
-80.64666667|37.72777778|1600|113805425My ascii data file looks like:
-85.71666667|35.43166667|0|113805426
-86.38055556|36.89527778|500|113805427
-81.24583333|37.49416667|3100|113805430
-83.63833333|40.65805556|997|113805432
-81.71027778|38.18055556|622|113805434
-85.04916667|41.36|861.7|49460912
-85.67944444|40.30833333|880|113805437
-80.76166667|37.475|2159|113805438The GRASS 6.0.2 interface generated v.in.ascii command with
output looks
like:
Maximum input row length: 42
Maximum number of columns: 4
Minimum number of columns: 4
column: 1 type: double
column: 2 type: double
column: 3 type: double
column: 4 type: integer
Building topology ...egistering lines: 1000 2000 3000 4000
5000> 5030 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Attaching centroids:Topology was built.
Number of nodes : 4468
Number of primitives: 5030
Number of points : 5030
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0The GRASS 6.1CVS interface generated v.in.ascii command with
output (not
including the warnings/errors, above) looks like:
format=point> fs=| skip=0 'columns=x double precision,y double
precision,z double
Minimum number of columns: 4That is, the comand never appears to complete...
Tom
I've use v.in.ascii on text files almost daily and have not
experienced problems like you describe. If you can isolate the
problem, the developers would probably be very likely to fix
the bug.
This is an important module.
As an aside, I use sqlite for my attributes, not Postgres and
that may
be the difference between our experiences (though Postgres
seems to be
the "preferred" database back end for GRASS)
David
On 3/16/06, David Finlayson <david.p.finlayson@gmail.com> wrote:
If I understand you correctly, you have a table in Postgres that
happens to contain x, y coordinates in addition to other
attributes> >> but is not a PostGIS layer. You were able to convert
the X,Y points
into a GRASS vector file (points) using v.in.db AND this new
vector> >> file seems to work in the lat long Location.
Now when you try to project the new vector file into a LCC
location it
fails. What is the error you are getting? That seems like it
should> >> work.
As a test, have you tried exporting the postgres table as a
csv file
(at least pointid, x and y) and then load the vector with
v.in.ascii?> >> You will be able to link the ID, X,Y CSV file back
to the original
postgres attribute table using the ID column. Does this simple
vector> >> file project?
David
On 3/16/06, Thomas Adams <Thomas.Adams@noaa.gov> wrote:
David,
Maybe you don't understand. The Postgres table is for points
and has the
lat-long location; using v.in.db one is required to identify
the x,y
location. The additional attributes are read as well, of
course. I can
successfully import the Postgres table into GRASS into my lat-
long> >>> location. If I then try to re-project the points into a
LCC projection
(from the LCC location), the v.proj does not seem to work. Is
this what
you previously understood I was tying to do or do now?
Who would know whether or not this can be done?
Thanks for you r responses…
Tom
Ah, I understand now. I'm afraid I can't help you with this.
I've only
used databases to hold attribute information not the
topology also. I
haven't tried PostGIS yet.
David
On 3/15/06, Thomas Adams <Thomas.Adams@noaa.gov> wrote:
List:
I have a Lat-Long location into which I have successfully
imported> >>>>> points from Postgres (a further question about this
further below). What
I want to do is to re-project the points into a Lambert
Conic Conformal
location using v.proj. When I try to do this, it does not
work — it
seems as though GRASS does not know how to do this. I have
been able to
do this successfully with points imported using v.in.ascii.
It seems I
am missing something, either conceptually or procedurally…
The further question about using v.in.db, the 'key'
parameter in the
documentation claims this is a string, which makes since to
me, but when
v.in.db is run, GRASS complains that an integer is needed.
I'm guessing
the integer that's supplied is the column/field number
(beginning with
'1'); if true, this seems to be inconsistent by what the
'x', 'y', and
'z' fields require — just a thought.
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033--
David Finlayson--
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033--
David Finlayson--
David Finlayson--
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033--
David Finlayson--
David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
