hello, i need a picture of my digital elevation model with a few
meteorological stations for a power point presentation. i thought i convert my
vector data to raster and merge the two rasters together.
but when i use v.to.rast i get only one station out of 30!?
the table of the vector looks like this:
cat | x | y | z | name
1 | 194197.23537 | 5191251.584895 | 1906 | Vent
2 | 226928.392144 | 5236860.658687 | 579 | Innsbruck-Flughafen
3 | 202576.650269 | 5192186.387956 | 1938 | Obergurgl
4 | 265000.467163 | 5225174.19567 | 643 | Mayrhofen
no matter which use option i take,i get only one point, which appears always
at the same coordinates also independent of the cat i choose.
using use=attr i get an error message:
GRASS 5.7.0:~/diss/grassdata > v.to.rast in=meteostation out=meteostation
use=attr col=name
Loading vector information ...ERROR: Column type not supported by
db_select_to_array()
using 'z' instead of 'name' works, but i get also just one point.
by the way, my point is very small, is there a possibility to make it larger?
does anyone have an idea how to get my items to the power point presentation?
model with a few
together.
of 30!?
cat | x | y | z |
name
i choose.
use=attr col=name
supported by
just one point.
thank you, sabine
Why don't you try to print all with the PNG driver (if
you would like a raster) or even better with ps.map?
In ps.map you have several options for controling the
graphical attributes of your points.
Miha Staut
___________________________________________________________ALL-NEW Yahoo! Messenger - sooooo many all-new ways to express yourself http://uk.messenger.yahoo.com
> model with a few
> presentation.
For a DEM, be sure to try NVIZ.
> together.
I don't think that's needed.
> of 30!?
v.to.rast only works on features with cats/attributes.
Perhaps the labeling isn't right. Maybe 'v.category option=add'?
See the "notes" section of the help page:
why not just to d.vect. The version in 5.7 lets you set icon= type,
size/color, and border color and is very nice.
Try d.out.png.
ps.map makes excellent output for a printed hardcopy, but for a
presentation I think using a sscreenshot of a display monitor works best
(or PNG driver). Try to get the monitor the size of the final image so
it doesn't get streched & uglified.
If you must use a PostScript plot in a presentation, the best conversion
I've found is to load it in the GIMP at ~ 144 dpi with strong anti-
aliasing on both the graphics and the text. Otherwise it comes out
grainy.
grainy.
Actually, it's better to use oversampling, i.e. rasterise the
PostScript at 300dpi or higher, then scale down to the desired size
using a program which provides an anti-aliased rescaling function.
E.g.:
