[GRASSLIST:3809] Import Arc/Info e00 data into 5.7
I've been wandering around the net for a while now, but haven't found a
good way to import DCW data into GRASS 5.7...
If you have a good solution to this problem, please let me know. Or if
there is no easy way, let me know, too, so I can start working on the
hard one...
Thanks alot,
Crischan
Je suis un homme du nord!
a good way to import DCW data into GRASS 5.7...
hard one...
Alphabet soup:
AFAIK...
DCW is now known as VMAP.
VMAP can be read with OGR's OGDI import filter.
So v.in.ogr is the GRASS 5.7 module to use, but you might have to use
ogr2ogr first? Also try the ogrinfo program.
see:
http://www.vterrain.org/Culture/vector.html
http://gdal.maptools.org/ogr/
http://gdal.maptools.org/ogr/drv_ogdi.html
http://www.terragear.org/docs/vmap0/coverage.html
Hamish
> hard one...
Alphabet soup:
AFAIK...
No, when having compiled OGR with OGDI support, then GRASS 5.7 should
read VMAP0 directly.
