I was using grass a bit a couple of years ago, but I have been away for a
while. Now I'm back and have started looking at 5.7, quite impressive, kudos
to the developers.
But..
I need to project some gps data to use them together with some raster maps in
a local (Norwegian) projection :
GRASS 5.7.cvs:~/NinaSather/Kart >g.proj -p
-PROJ_INFO-------------------------------------------------
datum : ngo48
towgs84 : 278.3,93.0,474.5,7.889,0.050,-6.610,6.21
proj : tmerc
ellps : modif_bessel
a : 6377492.0175999999
es : 0.0066743722
f : 299.1528128500
lat_0 : 58.0000000000
lon_0 : 8.3895830000
k_0 : 1.0000000000
x_0 : 0.0000000000
y_0 : 0.0000000000
As fas as I can see, those values are correct, but anyhow, the gps data ends
up about 300 meters off from where they should be (see
http://sickel.net/gps.html for an illustration) It looks like some kind of
datum / ellipse error, but I have no idea how to fix that (Except for
identifying a few pass points and write a transformation script) I have a
table of dx,dy,.dz values for my local projection and I have a feeling that
those are somehow connected to the towgs84 parameter, but I don't see how to
set those.
Btw, if anybody among you are reading 'Landscape and Urban planning' the maps
in
Hanne Sickel, Margareta Ihse, Ann Norderhaug and Morten A. K. Sickel: How to
monitor semi-natural key habitats in relation to grazing preferences of
cattle in mountain summer farming areas: An aerial photo and GPS method study
Landscape and Urban Planning, Volume 67, Issues 1-4, 15 March 2004, Pages
67-77
are made using grass. Each map made using two outputs using ps.map (5.0.0) and
combined in the gimp, making the upper layer semi-transparent. Feel free to
contact me if anybody have any questions regarding the production line.
Morten Sickel
http://sickel.net/
Drøbak, Norway
