Install the libraries from Lorenzo Moretti's binaries.
<http://wwwamb.bologna.enea.it/forgrass/>
Fast mirrors at:
EUROPE http://rea.ei.jrc.it/netshare/kaplan/grass_mirror/ (Jed O. Kaplan @ JRC)
USA http://www.public.asu.edu/~cmbarton/files/grass_osx/ (my site)
Make sure you DON'T have the July 1 2004 libraries (see the note on Lorenzo's site about these).
Once you install them, you need to make sure that you add /usr/local/grasslib/bin to your path. If you have installed Lorenzo's Mac OSX binaries, this is already taken care of.
I suppose that the other possibility is that you have a path problem, if you have already installed these binaries and Lorenzo's libraries.
Check your path by typing $PATH <return> in an XWindows terminal after you attempt to start GRASS. It should include the grasslib folder indicated above.
Hope this helps.
Michael
On Jul 6, 2004, at 10:01 PM, Multiple recipients of list wrote:
Hello
I am trying to start up Grass on a Mac G5 10.3.4 machine with X11. The GUI window pops
up on launch, but it opens a "grass57" terminal window with the info below. It seems that
things are not loading properly. Can anyone offer a suggestion?Thanks,
------S
Application initialization failed: Can't find a usable init.tcl in the following
directories:
@TCL_IN_FRAMEWORK@ /usr/lib/tcl8.4 /lib/tcl8.4 /usr/library /library /tcl8.4
.4/library @TCL_IN_FRAMEWORK@
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
