[GRASSLIST:3830] Re: Startup problems - OSX 10.3.3
As far as the libraries are concerned, I installed the latest (July 1?) versions. I am not sure if I
need to uninstall the old ones. If I need to do that, does anyone know how?
My "$PATH" results are below:
GRASS 5.7.-cvs:~ > $PATH
bash: /Applications/Grass/grass57/bin:/Applications/Grass/grass57/scripts:/usr/
11R6/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Users/spdorsey:/usr/bin:: No such file
r directory
Thanks for all your help!
------------------------S
Install the libraries from Lorenzo Moretti's binaries.
  <http://wwwamb.bologna.enea.it/forgrass/&gt;
Fast mirrors at:
    EUROPE http://rea.ei.jrc.it/netshare/kaplan/grass_mirror/ (Jed O.
Kaplan @ JRC)
     USA http://www.public.asu.edu/~cmbarton/files/grass_osx/ (my site)
Make sure you DON'T have the July 1 2004 libraries (see the note on
Lorenzo's site about these).
Once you install them, you need to make sure that you add
/usr/local/grasslib/bin to your path. If you have installed Lorenzo's
Mac OSX binaries, this is already taken care of.
I suppose that the other possibility is that you have a path problem,
if you have already installed these binaries and Lorenzo's libraries.
Check your path by typing $PATH <return> in an XWindows terminal after
you attempt to start GRASS. It should include the grasslib folder
indicated above.
Hope this helps.
Michael
On Jul 6, 2004, at 10:01 PM, Multiple recipients of list wrote:
> Hello
> Â I am trying to start up Grass on a Mac G5 10.3.4 machine with X11.
> The GUI window pops
> up on launch, but it opens a "grass57" terminal window with the info
> below. It seems that
> things are not loading properly. Can anyone offer a suggestion?
> Thanks,
> ------S
> Application initialization failed: Can't find a usable init.tcl in the
> following
> directories:
> Â Â @TCL_IN_FRAMEWORK@ /usr/lib/tcl8.4 /lib/tcl8.4 /usr/library
> /library /tcl8.4
> .4/library @TCL_IN_FRAMEWORK@
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
