After recompiling from CVS, this is what I get when starting 57:
Hit RETURN to continue
Starting GRASS ...
/usr/local/grass-5.7.cvs/etc/Init.sh: g.gisenv: command not found
///.gislock: Permission denied
ERROR: /usr/local/grass-5.7.cvs/etc/lock:
tatel is currently running GRASS in selected mapset. Concurrent use not
allowed
I guess this is somewhat dumb, but I can't find it.
Were there any errors when building GRASS? Try running "make" again.
Note that the 5.7 build system no longer aborts at the first error; it
will compile as much as it can. Even if "make" completes, some modules
may not have been built.
