[GRASSLIST:3898] BoundingBox in eps not found by ps.map
hello everybody,
i want to include an eps file (made with adobe acrobat 6.0) into a ps.map map, but ps.map complains that the bounding box cannot be found. i checked the eps file and that seems to be correct as %%BoundingBox is given.
any ideas?
cheers
works for me....
[tested with GRASS 5.7]
e.g. spearfish data set:
ps.map out=test.ps << EOF
raster elevation.dem
eps 50% -40%
  epsfile /usr/lib/tk8.3/images/logo.eps
  end
mapinfo
  where 0.5 8.5
  end
end
EOF
gv test.ps
here is the code, from 5.7's ps/ps.map/eps.c:
    /* looking for bbox */
    while ( fgets(buf, 200, fp) != NULL )
        if (sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf",
    llx, lly, urx, ury) == 4)
            fclose (fp);
            return (1);
    fprintf (stderr,"Bounding box in eps file <%s> was not found\n", eps);
    fclose (fp);
    return (0);
so make sure the %%BoundingBox: statement has 4 numbers after it.
I don't know why it would fail otherwise.
Hamish
