Hi Glynn, Marcus
As you say, after updating again from cvs I compiled 5.7 succesfully with:
make mixclean
make mix
make distclean
./configure
make
Thank you very much for your help.
Best regards,
Roman
O----- Jatorrizko Mezua -----
Norengandik: Markus Neteler <neteler@itc.it>
Data: Azteazkena, Uztaila 14, 2004 9:25 am
Gaia: [GRASSLIST:3901] Re: concurrent use
On Wed, Jul 14, 2004 at 12:41:35AM +0100, Glynn Clements wrote:
> tatel@euskalnet.net wrote:
> > After recompiling from CVS, this is what I get when starting 57:
> > /usr/local/grass-5.7.cvs/etc/Init.sh: g.gisenv: command not foundIMPORTANT (concerns all users compiling a fresh GRASS 5.7 from CVS):
Due to the change from hard links to soft links, a recompilation
requires a cleaned binary tree.
I had the same problem and solved it my runningmake distclean
configure ...
makeThe change from hard to soft links is somewhat not discovered
by the Makefile system. So simply run 'make distclean',
then recompile and the problem should be gone.Subsequent recompilations should *not* need 'make distclean'
every time. It's just required to migrate from hard to soft
links.Markus Neteler
