I have attribute data linked into a shape file using PostgreSQL. My
problem is I can't figure out how to produce a map of a given attribute
in the associated postgresql database.
Here's what I've done to set things up:
db.connect driver=pg database="dbname=alpac_netdown,user=caumann"
SHPDIR=/home/caumann/amedata/netdown/L3/coverages/
DBFDIR=/home/caumann/amedata/netdown/L3/data/
v.in.ogr -o dsn="$SHPDIR" \
output=l3a_fin_n83 layer=l3a_fin_n83
db.copy from_driver=dbf from_database=$DBFDIR \
from_table=l3a_net_final \
to_driver=pg to_database="dbname=alpac_netdown,user=caumann" \
to_table=l3a_fin_n83_att
v.db.connect -o map=l3a_fin_n83 table=l3a_fin_n83_att field=1 \ key=OID
v.db.connect -p map=l3a_fin_n83
## cgrp is one of the columns in the database and it has has 5
## values: C, D, CD, DC and "" or NULL or missing.
Now I want to produce a map with different colors for each of the
different values of cgrp for each polygon in the map. The map should
have 4 (or 5?) colors.
d.vect -c map=l3a_fin_n83 field=1 type=area display=attr attrcol=cgrp
The above produces a map with a large number of colors and is clearly
not correct.
d.vect map=l3a_fin_n83 field=1 type=area display=shape attrcol=cgrp \
where="cgrp='D'" col=red
Produces nothing. Why doesn't it like my query?
I'm sure there's a way to do this, I just can't figure out the different
flags to d.vect.
Many Thanks!
Craig
