Hi!
I'm wondering if anyone has tried to compile Mark Lake's r.cva module on 5.3. Is that possible?
Reason behind the question is that I yesterday tried to compile 5.0.3 on a pc (AMD processor, Suse 8.2 pro) in my home. After some trouble with diverse libraries (GD, tclkt and BLAS/Lapack) missing I got it to compile. But BLAS/LAPACK was not found it reported at the end of ./configure (but installed from SUSE 8.2 DVD, are they broken/too old?)
Then I tried to compile r.cva, following the instructions. However, issuing gmake5 made nothing happen, error being unrecognized command. 'Locate gmake5' found it, so issuing it with full path made it execute, but it then processed the whole sourcetree (a lot of modules flashed by! All?). I'l try another machine this evening, and certainly be back with other questions then!
regards
larsf
Lars Forseth
Archaeologist Nord-Trøndelag County Council
Tlf: 74111270 Mob: 97528143
(attachments)
Lars Forseth (E-post).20440DEFANGED-vcf (337 Bytes)
I believe there are some instructions included in the r.cva
source package that tell you to adjust the binary paths
in your GRASS source tree (INSTALL.txt).
If you don't the compiled modules are likely to end
up in your source tree instead of the GRASS 5 binary
installation tree (usually /usr/local/grass53 or similar) and
you won't be able to execute them.
However, if you get it to compile and install it still won't
be very useful because it is essentially GRASS 4.X code and
does not handle floating point raster, GRASS 5 sites format
or NULL values.
I have done a conversion of r.cva to GRASS 5.0/3/7
that works with floating point und NULL values and also
uses the new sites format.
I have tried to email Mark a while ago to ask him if I was
allowed to distribute this updated version but got no
reply so far.
I am a bit reluctant to just publish his code without his
expressed affirmation.
I will try to contact him again about it and hopefully
get a reply (Mark, do you read this -- please answer!).
Benjamin
On Mon, 19 Jul 2004 09:48:59 +0200
"Lars Forseth" <lars.forseth@ntfk.no> wrote:
Hi!
regards
larsf
Lars Forseth
be very useful
I disagree---I have obtained very useful results with it using the following work-arounds:
Multiply it by 100 or 1000 or whatever is convenient, prior to doing the analysis
Use r.to.sites and a raster layer for your input sites
or NULL values.
I don't recall that being a problem---can you convert them to zeros with r.null though?
reply so far.
I agree it would be really good to get r.cva into GRASS---it is a really excellent module.
Paul
On Mon, Jul 19, 2004 at 09:48:59AM +0200, Lars Forseth wrote:
Hi!
You don't need BLAS/LAPACK currently:
--without-lapack --without-blas
Maybe in future we'll use it.
