[GRASSLIST:3975] d.nviz command
Hi
I am a new user of GRASS, currently i am using the 5.0.3 version. In the command manual i have seen the command “d.nviz” for animmation. But when i am trying to use that command its showing the message “bash: d.nviz command not found”. The “nviz” command is working fine. I want to know wheather this “d.nviz” command is working or not or wheather this command is replaced by some other command. Hope to get some help.
With thanks and regards
Bhriti Bhushan
Indiatimes Email now powered by APIC Advantage. Help!
Help
Click on the image to chat with me
the command manual i have seen the command "d.nviz" for animmation.
d.nviz is a new module and only present in the most recent releases.
Note the online help pages are for GRASS 5.3 and 5.7 commands, not 5.0.3.
"bash: d.nviz command not found". The "nviz" command is working fine.
I want to know wheather this "d.nviz" command is working or not or
some help.
In the GRASS 5.3 source tree, it can be found in:
  src/grass/grass53/src.contrib/GMSL/d.nviz
Compile with 'cd src/grass/grass53/src.contrib/GMSL/d.nviz ; gmake53'
[that is if you compiled the rest of GRASS 5.3 from source]
I don't think it exists in 5.7 yet.. I guess we should fix that.
Hamish
> some help.
Fixed. Now it's also included in 5.7.
