Following installation I am receiving the following error message:
"couldn't execute "C:\cygwin\bin\g.gisenv": no such file or directory .... Is this something to do with the CYGWIN X monitor?
Could someone help please?
Mike
Mike
It looks like grass is not installed correctly on your computer.
g.gisenv is a core grass module (it manages the GIS enviroment settings)
It's likely that other stuff is missing too, just that g.gisenv is the
first internal grass program it tries.
The g.gisenv program should be located in:
/usr/local/grass57_[...]/bin/
and
/usr/local/grass57_[...]/etc/bin/cmd/
'grass57' should be in /usr/local/bin/
and when finally running GRASS, "echo $PATH" should show
/usr/local/grass57_[...]/bin/ as the first entry.
I take it you are starting grass with:
cygwin$ startx
cygwin-xterm$ grass57
make sure the path inside the grass57 script is correct.
(/usr/local/bin/grass57 is just a text file)
If that doesn't work, just try reinstalling.
Did you install from the "/" directory in cygwin? I think it expects
that.
I don't think it has anything to do with X.
Hamish
Hamish,
Thank you for your time. I've gone through your suggestions and no luck I'm
afraid. I'll copy the GRASSLIST in on this to keep everyone up to speed.
Any other ideas would be very much appreciated.
Mike
om>
Cc: <GRASSLIST@baylor.edu>
Sent: Wednesday, July 28, 2004 1:04 AM
Subject: Re: [GRASSLIST:4024] Installation Grass5.7 problem
> .... Is this something to do with the CYGWIN X monitor?It looks like grass is not installed correctly on your computer.
first internal grass program it tries.The g.gisenv program should be located in:
/usr/local/grass57_[...]/bin/ -- Yes
and
/usr/local/grass57_[...]/etc/bin/cmd/ -- Yes'grass57' should be in /usr/local/bin/ -- as a shortcut pointing to
C:\cygwin\usr\local\bin\grass-5.7.0-i686-pc-cygwin-24_06_2004
- GRASS 5.7.0:~ > echo
$PATH
/usr/local/grass5.7.0-i686-pc-cygwin-24_06_2004/bin:/usr/local/grass5.7.0-i6
86-pc-cygwin-24_06_2004/scripts:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:
/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdrive/c/program
files/Java/j2re1.4.2_04/bin:/cygdrive/c/JavaSpeech/ibmjs/lib:
GRASS 5.7.0:~ >
cygwin$ startx --Yes
cygwin-xterm$ grass57 -- Yes (my actual prompt is: $ grass57)
Then I am into the usual GRASS5.7.0 startup screen where my Location is
spearfish; Mapset is PERMANENT; and Database is /data/ -- where the actual
physical location is c:\cygwin\data\spearfish
Hitting esc/enter produces the usual Grass Welcome screen.
Then, entering 'tcltkgrass $' attempts to start up the GRASS graphical
interface but then fails with the following error message:
Error in startup script
window name "loading" already exists in parent
while executing
"label .loading -text {Loading ...}"
(file
"/usr/local/grass5.7.0-i686-pc-cygwin-24_06_2004/tcltkgrass/main/gui.tcl"
line 1881)
invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
invoked from within
"if [catch {source $env(TCLTKGRASSBASE)/main/gui.tcl}] {
set env(TCLTKGRASSBASE) $env(GISBASE)/tcltkgrass
source $env(TCLTKGRASSBASE)/main/gui...."
(file "/usr/local/grass5.7.0-i686-pc-cygwin-24_06_2004/bin/tcltkgrass"
line 26)
OK
tcltkgrass & -- Done
This is the content of /usr'local/bin/grass57
#! /bin/sh
# $Id: grass.src,v 1.4 2003/12/08 17:18:54 paul Exp $
# MODULE: GRASS Initialization
# AUTHOR(S): Justin Hickey - Thailand - jhickey@hpcc.nectec.or.th
# PURPOSE: The source file for this shell script is in
# src/general/init/grass.src and is the grass startup script. It
# requires a source file because the definition of GISBASE
# is not known until compile time and is substituted from the
# Gmakefile. The script also sets the default user interface and
# parses the command line options for interface and help flags.
# Any remaining options are passed to Init.sh.
# COPYRIGHT: (C) 2000 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
trap "echo 'User break!' ; exit" 2 3 9 15
# Set the GISBASE variable
GISBASE='/usr/local/grass5.7.0-i686-pc-cygwin-24_06_2004'
export GISBASE
exec "$GISBASE/etc/Init.sh" "$@"
And this is the actual physical path to GISBASE:
C:\cygwin\usr\local\grass5.7.0-i686-pc-cygwin-24_06_2004
If that doesn't work, just try reinstalling. Done twice with no luck.
that. YesI don't think it has anything to do with X.
Hamish
Thanks again for your time,
Mike
Dr. Michael Francis Ph.D (Lancaster); M.Sc (Lancaster); M.Sc (London); BA
Hons (CNAA) MBCS MCIT MIHT
Senior Lecturer in Information Systems
Director, Merseyside Regional Research Laboratory,
Liverpool John Moores University,
Liverpool,
England
Telephone 079 600 600 72
Web Page http://www.mikhul1.f2s.com
