[GRASSLIST:4025] More OGR lib compile fun
After guessing that the compilation error messages such as:
OBJ.i686-pc-linux-gnu/describe.o(.text+0x3f):/home/bob/grass-5.7.0/db/drivers/ogr/describe.c:33: undefined reference to `OGR_DS_GetLayer'
might have something to do with a library not found, I tried this:
sudo cp lib/libgdal.so* /usr/local/pgsql/lib
sudo cp lib/libgdal.so* /usr/local/lib
sudo cp include/ogr_api.h /usr/local/include
Still no luck. FYI I'm doing:
~/grass-5.7.0/db/drivers/ogr> make
to speed things up a bit. Any idea what I might be messing up here? Am
unable to find any help on the web or in the manuals, so this must be
a truly obvious problem ...
Adios,
Chris Cornuelle
bob at xmission dot com
How GDALLIBS, GDALCFLAGS and USE_OGR is set
in grass51/include/Make/Platform.make ?
Radim
Radim,
In grass-5.7.0/include/Make/Platform.make we have:
gdal/OGR
GDALLIBS = -ldl
GDALCFLAGS =
USE_OGR =
FYI:
/usr/lib> ls libdl*
libdl.a libdl.so@
However, during configure I did:
CFLAGS="-g -Wall" ./configure --without-fftw --without-gdal --without-opengl --with-postgres-includes="/usr/local/pgsql/include" --with-postgres-libs="/usr/local/pgsql/lib"
and
NVIZ: no
X11 support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: no
OpenGL(R) support: no
ODBC support: yes
FFTW support: no
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: no
GLw support: no
NLS support: no
Readline support: no
C++ support: no
openDWG support: no
GDAL support: no
OGR support: no
So since I attempted to disable OGR in order to get a working grass57
executable, this seems not to have happened. Or?
Thanks. :^)
Thus spake Radim Blazek (blazek@itc.it):
Radim
Adios,
Chris Cornuelle
I have no explanation how/where '-ldl' was added to GDALLIBS.
Normally, if --with-gdal is used, it contains path to GDAL lib
and GDAL lib.
Compilation of ogr driver is conditional and it was using
  ifneq ($(strip $(GDALLIBS)),)
which I changed to
  ifneq ($(strip $(USE_OGR)),)
OGR driver is used only for external data (v.external)
Radim
On Tuesday 27 July 2004 17:10, C.S. Cornuelle wrote:
Radim,
gdal/OGR
GDALLIBS = -ldl
GDALCFLAGS =
USE_OGR =
FYI:
/usr/lib> ls libdl*
libdl.a libdl.so@
Radim,
FYI I edited ~/grass-5.7.0/include/Make/Platform.make to remove
the offending '-ldl' and now compilation dies here:
gcc -rdynamic -L/home/bob/grass-5.7.0/dist.i686-pc-linux-gnu/lib
-L/usr/local/pgsql/lib -o
/home/bob/grass-5.7.0/dist.i686-pc-linux-gnu/etc/bin/cmd/d.path
OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/select.o
-lgrass_display -lgrass_raster -lgrass_vect -lgrass_dig2 -lgrass_dgl
-lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase
-lgrass_dgl -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lz -lm -lz
/home/bob/grass-5.7.0/dist.i686-pc-linux-gnu/lib/libgrass_vect.so:
undefined reference to `V2_close_ogr'
undefined reference to `V2_open_old_ogr'
A bit of looking around and messing about did not solve anything, so
I remain stumped. :^(
Given this, I'll reinstall grass57 from scratch and try again. Please
let me know if the above errors have an easy fix. I'm guessing that
'configure' is my problem ...
Thanks.
and GDAL lib.
which I changed to
Radim
> Radim,
> gdal/OGR
> GDALLIBS = -ldl
> GDALCFLAGS =
> USE_OGR =
> FYI:
> /usr/lib> ls libdl*
> libdl.a libdl.so@
Adios,
Chris Cornuelle
It seems that GRASS was configure as if it had GDAL, but
definition is missing. Set your
grass51/include/Make/Platform.make:
GDALLIBS =
GDALCFLAGS =
USE_OGR =
grass51/include/config.h:
#undef HAVE_OGR
But GDAL/OGR is very useful, I recommend to install GDAL.
Radim
On Wednesday 28 July 2004 19:33, C.S. Cornuelle wrote:
Radim,
Thanks.
> and GDAL lib.
> which I changed to
> Radim
> > Radim,
> > gdal/OGR
> > GDALLIBS = -ldl
> > GDALCFLAGS =
> > USE_OGR =
> > FYI:
> > /usr/lib> ls libdl*
> > libdl.a libdl.so@
Thanks. :^)
FYI I managed to install grass 5.3 without incident.
GDALLIBS =
GDALCFLAGS =
USE_OGR =
#undef HAVE_OGR
Radim
> Radim,
> Thanks.
> > and GDAL lib.
> > which I changed to
> > Radim
> > > Radim,
> > > gdal/OGR
> > > GDALLIBS = -ldl
> > > GDALCFLAGS =
> > > USE_OGR =
> > > FYI:
> > > /usr/lib> ls libdl*
> > > libdl.a libdl.so@
Adios,
Chris Cornuelle
