[GRASSLIST:4026] .e00 and grass57
What is the recommended technique to import .e00 files into grass57?
Kirk
[Monday 26 July 2004 17:36] From Kirk R. Wythers
Suggestion
1. convert the .e00 to a coverage file with avcimport
http://avce00.maptools.org/
2. Import the coverage with v.in.ogr
Et voila
Experience shows that you may want to fiddle a bit with the dbf created in
step 1, to make sure that the cat' names are less than 12-character long (or
ten), that the category names are legal (viz, that you don't have a DATE one,
for example, as it's a reserved word)...
But it's fairly straightfowrd
Soil & Water Laboratory
Dept. of Biological & Environmental Engineering
Cornell University
ITHACA, NY 14853
Tel: (607)255.2463
Suggestion
Et voila
Another option might be:
e002pg
http://e00pg.sourceforge.net/
E00 -> PostGIS -> v.external/v.in.ogr
I didn't try it yet.
Suggestion
Et voila
(or ten), that the category names are legal (viz, that you don't have a
DATE one, for example, as it's a reserved word)...
Now can be done with 'cnames' option in v.in.ogr.
Radim
