[GRASSLIST:404] r3.to.rast problem
Hello List,
I have a little problem with r3.to.rast: when I display the created slices, I
see that they are divided into squares. Does anybody know why they are
divided?
Istvan
Hi Stefán,
i have tried to reproduce this behaviour.
It appears if the 2d region setting has a lower resolution then the 3d region setting.
In r3.to.rast, the 3d region will automatically changed to the current 2d resolution, if they are different.
The squares are huge if the regions are slightly different:
In spearfish60 "res=102 res3=100", produces big squares,
res=120 res3=100 ... smaller squares.
I guess this is related to the neares nighbour method within
the g3d lib?
You can avoid this while using data with equal resolution and region settings.
Best regards
Soeren
On Monday 27 March 2006 11:04, Stefán István wrote:
Hello List,
divided?
Istvan
