[GRASSLIST:4062] Re: how to create GUI in grass5.7
This discussion is a bit baffling. What version do you have?
The current version of GRASS 5.7 normally opens with the display manager (command d.m) active, and a complete TclTk menu system for all GRASS commands.
If you have a current version and have somehow turned off the GUI, you can restart it as Didit describes below or by starting with grass57 -tcltk. Typing tcltkgrass & from the GRASS xterm prompt while running GRASS will start the GUI temporarily (i.e., for that session).
If you have an older version of GRASS 5.7 (e.g., early 2004 or before) and want to add the current GUI, you can download and install it from my website at <www.public.asu.edu/~cmbarton/grass.htm>. Note, however, that this GUI contains menu entries for GRASS modules that have been added since the pre-GUI version.
Hope this helps.
Michael
On Aug 1, 2004, at 10:01 PM, Multiple recipients of list wrote:
If you always want to open up grass with a graphical interface, just change your
.grassrc5 file with a unix text editor like pico. Change the line that says
GRASS_GUI: text
to
GRASS_GUI: tcltk
with grass 57 the file might be called .grassrc57
Good luck,
Ian
Quoting Didit Ahendra <dee2t2001@yahoo.com>:
hi all,
I use grass 5.7 with my vector data to make Geographical Information System
about transportation.
A long this time I just use and type grass command on grass prompt to
operation my vector data.
I want ask you all, about GUI (Graphics User Interface) in grass.
I want to make a button in a windows that I can click to do some grass
command.
what should I do to make GUI in grass 5.7?
would you tell me how to make a button, please?
thank's for your help before.
regards,
Didit
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
