Again, I'm not sure how to do this with vector-only solution, and I
don't think it is appropriate to use at a 10m raster resolution when
the river is 30m wide. You error will always be half the width of the
river.. not acceptable.
I was using it for looking at the width of fjords 1km wide, there it
works fine as +-10m isn't a big deal.
Maybe do a small section of the river at a time at 1m resolution?
That is one of my maps, used as both a cost and a MASK map. That map
only covers the sea area. r.grow spread it out in all directions by one
cell, so starting points (the coastline) are always inside the MASK
region. Before for my data 50% of the time the coastal points were 1
cell on land side and ignored. I wanted the final map to be all "1"
values. (cost to move to next cell is 1)
alternate (still raster step) solution:
Change lines to boundaries (v.type); load into v.digit and make lines
into a closed area, add a centroid. Make sure centroid has a category
number (v.category). Then v.to.rast, r.thin, r.to.vect.
Alle 01:05, martedì 14 marzo 2006, Hamish ha scritto:
Hi Hamish!
I am following this way, and the solution it's very nice (another point for
GRASS! ). Here you can see the output at 1m resolution:
The solution is very nice for 2D, but they told me to add manual Z values to
the points.
For this i was planning to create 2 differents file vector file for
each,converting lines to points, do the average between the Z values and
assign to the axis..
What do you think?
Luca
"E' molto più bello sapere qualcosa di tutto, che tutto di una cosa (Blaise
Pascal)."
GENTOO-GIS Development Team
jabber: casagrande@jabber.linux.it
