[GRASSLIST:4101] Install grass57-5.7.0-2mdk.i586.rpm
I'm beginner in linux world and interested in GRASS.
i try to install grass57-5.7.0-2mdk.i586.rpm in my computer(mandrake10)
and i found :
error: Failed dependencies:
        libfftw.so.2 is needed by grass57-5.7.0-2mdk
        libgdal.so.1 is needed by grass57-5.7.0-2mdk
I have already install gdal and fftw by compiling their source
( gdal-1.2.1, fftw-3.0.1) and it was done.
but why it still error while i'm trying to install grass57,
i mean the same error that i founded.
Thanks
sei kian
and i found :
RPM only knows about files which were installed from RPMs. Because you
didn't install GDAL and FFTW via RPM, RPM doesn't know that they are
installed, so it is telling you that you need to install them.
Searching on rpmfind.net shows GDAL and FFTW RPMs for Mandrake.
Alternatively, you can use "rpm --force ..." to install ignore the
dependency issues. However, note that GRASS won't work with FFTW
3.0.1; it requires FFTW 2.x.
On Thu, Aug 05, 2004 at 10:52:56AM +0700, seikian@enciety.com wrote:
and i found :
The documentation recommends to download the related RPMs
(not to compile yourself):
http://grass.itc.it/grass57/binary/linux/mandrake.html
You should also download following RPMs:
    * gdal, gdal-python, libgdal
    * proj, libproj
    * libfftw2
I've made it more outstanding on that page.
> Hi all,
> and i found :
hello everybody, but what to do in matter if i have compiled it by my self
because minesota mapserver instalation ?
thanks
    * proj, libproj
    * libfftw2
> > Hi all,
> > and i found :
thanks
No problem of course. It's a recommendation to users who want
to minimize installation issues. Expert users may partially
compile or completely compile the required packages.
> > > Hi all,
> > > computer(mandrake10) and i found :
> self because minesota mapserver instalation ?
> thanks
ok thanks, i thing so :slight_smile:
thailon
could you tell me, what is the next step after i install grass5.7
I read the tutorial but i couldn't find the way using Grass with C.
my goal is using Grass to develop my project (using C language)
do you have any examples in C/C++ ?
thanks
