Hi folks,
I tried to start a new GRASS project with GRASS 5.0.2 for the first time and
apparently no one fixed the old problem with the tcktkgrass. Now when I try
to launch I get the following:
[Kurt-Springss-Computer:~] kurtsprings% ERROR: LOCATION_NAME not set
[Kurt-Springss-Computer:~] kurtsprings% grass5
Cleaning up temporary files.....
Starting GRASS ...
Error in startup script: can't read "env_location": no such variable
while executing
"set location $env_location"
(procedure "searchGISRC" line 23)
invoked from within
"searchGISRC $gisrc_name"
(file "/usr/local/grass5/tcltkgrass/script/gis_set.tcl" line 1)
/usr/local/grass5/etc/Init.sh: GISDBASE: parameter null or not set
What was the file I have to remove to fix this? I suspect I still have to
use grass5 -text to start a new project.
I am using GRASS 5.0.2 from OPEN OSX. Are there any other surprises waiting
for me?
Kurt Springs
Kurt Springs said:
Hi folks,
and
try
Starting GRASS ...
while executing
invoked from within
Yes, this means that LOCATION_NAME is not set in your .grassrc5 file.
Either start with -text or remove .grassrc5.
BTW, even when starting up with the tcltk GUI, you still are sent back to
text mode when creating a new location, so launching directly with -text
doesn't make such a big difference.
Moritz
