Hi!
I am working with Grass 5.7.0.
To fill some null-cells in a float-raster-heightmap I tried to utilize r.fillnulls. The script produces values far away from the surrounding values.
So I looked into this script and found the command:
v.surf.rst -v ...
My heightmap isn't cell so - it doesn't work. Might be because of high temperatures in my town but I remembered about a tool called r.support in older grass-versions, which generated the cell-headers.
So I searched for this tool in the manuals and there are some dead links to it - it is not there.
Can you give me a hint about how to solve the problem?
Greetings
Martin
On Sun, Aug 08, 2004 at 10:13:13PM +0200, Martin May wrote:
Hi!
values.
v.surf.rst -v ...
do you mean
r.to.vect -v
Could you post the r.info output of your temperatures map?
Also the r.fillnulls command line you used?
Please indicate the dead links (then we can fix them).
Greetings
Martin
Hello together, hello Markus!
Thank you Markus - your response brought me to the solution:
r.info says: The raster IS cell.
The problem is in r.fillnulls:
The command
v.surf.rst input=pointfeatures elev=rasterresult segmax=700
takes the ‘cat’-field, I think because it is the primary key in the generated pointfeature-table.
When I take this command:
v.surf.rst input=pointfeatures elev=rasterresult segmax=700 zcol=value
everything works fine.
So perhaps the r.fillnulls-script needs an update - I think my data is not very special.
Greetings
Martin
Am 08/09/2004 09:45 AM schrieb Markus Neteler:
Hi!
values.
v.surf.rst -v ...
do you mean
r.to.vect -v
Greetings
Martin
