Hi All,
I'm using the precompiled OS X binaries from lorenzo moretti (OS X 10.2.8). I'm having problems with r.plane. As in the script will not finish and it writes a completely flat plane. Has anyone had the same problem? Also after I wrote a script my self to do the job (it's not working well yet) I'm having problems with importing the raster to v5d. My version of v5d is the latest Vis5d for OS X and it will not recognize the file created by r3.out.v5d as a v5d file. Does anyone have any suggestions?
On another matter: can graphics drawn with d.graph be redrawn by some method after the monitor window is moved or resized? I'd like to write a script that draws a cross section to a monitor using output from d.profile. I thought d.graph would be useful for that.
thanks
Mike
