Hi list,
i work on grass5.7 and want to use postgres to store attribute tables.
I have a shapefile (siteid_o_s) imported into Grass and an attribute table (siteid_o_s) in postgres.
Now i try with db.copy to export the shapefile into postgrass
first a test:
v.db.connect -p map=siteid_o_s
field <1> table <siteid_o_s> in database </home/disen/data/grassdata/Upperengadine/disen/dbf/> through driver <dbf> with key <cat>
seems to work
the command:
db.copy from_driver=dbf from_database=./ from_table=siteid_o_s to_driver=pg to_database="dbname=mydb,user=disen" to_table=siteid_o_p
D3/3: db_copy_table():
from driver = dbf, db = ./, table = siteid_o_s
to driver = pg, db = dbname=mydb,user=disen, table = siteid_o_p, where = (null)
D3/3: db_driver_open_database() driver=pg database definition = 'dbname=mydb,user=disen'
D3/3: parse_conn : dbname=mydb,user=disen
D3/3: token 0 : dbname=mydb
D3/3: token 1 : user=disen
D3/3: host = (null), port = (null), options = (null), tty = (null), dbname = mydb, user = disen, password = (null)
D3/3: pgtype = 16, name = bool -> type = 16
D3/3: pgtype = 18, name = char -> type = 9
D3/3: pgtype = 20, name = int8 -> type = 3
D3/3: pgtype = 21, name = int2 -> type = 1
D3/3: pgtype = 23, name = int4 -> type = 2
D3/3: pgtype = 25, name = text -> type = 12
D3/3: pgtype = 26, name = oid -> type = 5
D3/3: pgtype = 700, name = float4 -> type = 6
D3/3: pgtype = 701, name = float8 -> type = 7
D3/3: pgtype = 1042, name = bpchar -> type = 10
D3/3: pgtype = 1043, name = varchar -> type = 11
D3/3: pgtype = 1082, name = date -> type = 13
D3/3: pgtype = 1083, name = time -> type = 14
D3/3: pgtype = 1114, name = timestamp -> type = 15
D3/3: pgtype = 1700, name = numeric -> type = 8
D2/3: pg : BEGIN
D3/3: select * from siteid_o_s
D3/3: SQL statement parsed successfully
D2/3: find_table(): table = siteid_o_s
DBMI-DBF driver error:
Table 'siteid_o_s' doesn't exist.
Error in db_open_select_cursor()
WARNING: Cannot open select cursor: 'select * from siteid_o_s'
WARNING: Copy table failed
the same error log appears when using
- not shapefiles, but grass vectors
- not same name for file and table (in postgres)
any ideas what is wrong?
Thanks dani
