[GRASSLIST:4154] reading coordinate values from shapefile
Hi list,
thanks to Radim's hint, i am able now to maintain attribute tables on postgres.
I'm not sure if it is a stupd question, but the next problem i didn't found a solution in the tutorials or FAQs is:
how to extract coordinate values from certain elements of a shapefile (for example the x/y-coordinates of a centriod of a certain polygon), but not interactively, but with specifying the element?
for example smth in this way:
select X_COOR, Y_COOR from shapefileXY where object_id = 1
Or is it better using ascii_files? but how to relate there coordinate values with elements of the file specified in the attribute tables?
Thanks dani
On Tuesday 10 August 2004 15:46, Daniel Isenegger wrote:
Hi list,
postgres.
Thanks dani
For points and centroids you can use v.to.db option=coor,
columns must exist.
Radim
