[GRASSLIST:4168] GRASS installation problem
Hello,
I'm a newbie GRASS user and I have a problem with installing the package.
I run WIN-XP (homeversion), NTFS, on a PIII 550Mhz, 512 Mb RAM
Multiboot system Win98(C) / WinXP(D)
Installed Cygwin according to the install-manual on the 5.0.3 download page
Installed X11 completely
Installed tcltc packages from the 5.0.3 download page, tcltk package of current Cygwin release was not installed.
Installed GRASS 5.0.3 according to install manual.
Started GRASS, textmode and filled-out the form about the project.
Then GRASS started
But that was it....when I use tcltkgrass& I get a bunch of errors
Via mailinglist I got these commands to try:
$ /usr/X11R6/bin/XWin.exe -multiwindow -clipboard &
worked fine, bunch of text running by in the bash-shell
(Cygwin/X Server appeared in the system tray)
$ grass5
text mode
selected the project, esc, enter
grass prompt appeared
d.mon x1
Then errors appeared again:
Can't bind to socket; already in use?
No socket to connect to for monitor <x1>.
Problem selecting x1. Will try once more
Whatever I try, it will not start.
The last two weeks I have tried (and failed) 5 times installing the cygwin/grass5.0 system.
I even tried to install the complete cygwin packages (except tcltk) with grass5.
I then see a window starting up, but exiting with errors.
Does anyone know this kind of problem and what to do to get it working properly?
Best regards,
Cees van der Mark,
Amsterdam, The Netherlands
Cees,
I think you will have better luck with GRASS 5.3 or GRASS 5.7. A number of problems have been corrected in these more up-to-date versions. You can get them in binary form from my site and Rich Greenwood (links to Rich on my site also). You should also install Rich’s GDAL binaries to give you lots of import/export options. And get the Spearfish demo data set for 5.3 and 5.7 to practice on. My site is http://www.public.asu.edu/~cmbarton/grass.htm. Rich Greenwood’s site is http://www.greenwoodmap.com. I hope this helps.
Michael Barton
On 8/11/04 2:31 AM, “van der Mark, C.J. ” cvdmark@xs4all.nl wrote:
Hello,
I’m a newbie GRASS user and I have a problem with installing the package.
Then GRASS started
But that was it…when I use tcltkgrass& I get a bunch of errors
$ grass5
text mode
d.mon x1
Can’t bind to socket; already in use?
No socket to connect to for monitor .
Best regards,
Cees van der Mark,
Michael Barton, Professor
School of Human Origins, Cultures, & Society
Arizona State University
Tempe, AZ 85287
Web - http://www.public.asu.edu/~cmbarton
